Best Bearings
#17
I am going to make a large order of bearings real soon would tko or 4c hobbies cut a discount on like 4 mbx6 bearing kits and three os eng bearing kits ceramic?
#18
I'll cut you a deal & 1/2
[email protected]
(we deal with TKO exclusively)
#21
I have used every bearing in the US and so far Avid holds up the best. I will use nothing but dollar bearings.
#22
#23
I like the tko $1 bearings throughout my drivetrain and in the clutch I use the tko special bearings. Well worth the $$ I am still looking for great engine bearings tko aren't bad but my last few ceramic sets don't last like they should. I am going to try some high dollar Bocca ceramic engine bearings and see how they go. Anyone have the ultimate engine bearing??
#24
reply
Boca Bearings - I have the orange seal ceramics & yellow seal ceramics through out my 4 rc cars and they are worth every dollar that you spend, nice free friction free rolling through out the drive train meaning that other parts of your car wear less including the engine as it spools up so much better and the cvd's and dog bones have less load on them when moving with out the friction added by cheaper bearings.....
I also run ceramic rear main engine bearings to help get the most out of the engines adding the little bit of extra rpm's too, Boca Bearings have ceramic ranges to suit your needs from cheaper car kits through to all out race kits, once you have tryed the boca ceramic range you would never go back.....
#26
Best Bearings
Boca bearings have served us well. Excellent bearing.
#27
Been there, done that. FOR MEthey dont last no longer than the bearings I run now for a buck. One thing I dont play with is my clutch. And no matter what bearings I use, I will change them often.
#28
i get what you saying about, the clutch but just in my exprience dollar clutch bearings and losi hd clutch, bearings have failed me before i ran one gallon.
than again i been using the king headz extended engine mount.
its all in personal likeing.
#29
Avid has good bearings, I just dont run them in my clutch. I run rev's in my chassis.
