rebound changes?
rebound changes?
hi there,
i have recently changed the amount of rebound i run in my shocks from full to 50% rebound. i check the rebound on a weekly basis and it changes after a meeting? is there a problem with the shock seals?
i am also having trouble setting the rebound on the front shocks i dont know what is causing it? i have watched the adam drake video of setting up the rebound but he makes it look so easy and it takes ages to get mine right?
i have been thinking of replacing the shafts, seals, pistons etc would this help?
many thanks in advance
lewis
lewis
hi there,
lewis
lewis
if your rebound is changing is could mean you have a leak somewhere. how long has it been since your changed the orings, bladder and plastic spacer in the shock? also is the tin coating still on the shaft?
i have a losi 8ight 1.0 rtr which i have converted with 2.0 chassis, shock towers etc. so the shock shafts are silver? but i was thinking of replacing them
many thanks
lewis
right i replaced the orings several gallons ago, i changed the bladders a couple of weeks ago and i have never replaced the plastic spacer (what is the plastic spacer?)
many thanks
lewis
many thanks
lewis
Get this, its cheaper and it has everything you need(except for shafts)
http://www.amainhobbies.com/product_...rce=google_ext
you have the RTR. the shock shafts on the roller are tin coated. Replace the shafts, replace the oring,and the spacer. That spacer will oval out and put stress on the orings which can cause a torn o ring.
i have thought of getting that and some shock shafts but is t worth it? how much would all of that cost if bought separately? i live in the UK so they cost about £20
many thanks
lewis
Doesn't drake use a closed cell foam under his bladder so his rebound is consistent? This way leaking does not fill up that air pocket and mess up the pressure.
many thanks losi_racer for the advise
lewis
i would say you might, have dirt cogged up on your o-rings.
my rebound totally went, away on the front of my truggy because of it.
but replace your o-rings, thats the main problem after each heat you race clean the dirt off the shafts and the 0-ring cartige also.
The 1.0 shocks have a thicker spacer in between the 2 o rings than the 2.0. Get the 2.0 shock spacers and see if that solves your problem.
i am going to get the team losi shock service parts because it has everything i need to keep my shock working well but does it have the 2.0 or the 1.0 shock spacer between the o rings?
many thanks
lewis
many thanks
lewis
When the shock is assembled and on the car, just how important is rebound? I mean, were talking very little pressure inside the bladder to push the piston out, but when you install the spring, just how effective can a foam compensator be against a metal spring?
but when i changed the rebound to 50% the car did not bounce about on the straight and i could keep the throttle open meaning i would be quicker. i noticed the difference, but i depends on whet track you are on
The service box has the 1.0 spacers in it.
