Shock Rebound adjustment >
Old 07-28-2010, 03:54 PM
Scott_Mantis's Avatar
Trader Rating: 15 (100%+)
Default Shock Rebound adjustment
Have done a bit of a search around the forum, but cant really find, any discussion on the effects of adjusting shock rebound would be great..
If it helps i have an RC8T..
Thanks...
Scott_Mantis is offline
Old 07-28-2010, 04:00 PM
K_B
K_B's Avatar
Trader Rating: 70 (100%+)
This might help. The last part of the video touches on rebound...
http://www.youtube.com/watch?v=HNJy7...ext=1&index=35
K_B is offline
Old 07-28-2010, 04:13 PM
Trader Rating: 36 (100%+)
The best info I've found regarding building shocks and rebound.
http://www.tytessman.com/tips/building_shocks.html
I do do one thing a little different when building, however. Ty shows you to install the o-rings n such inside the shock, then run the shaft through. I disagree with this as I think it has more of a tendency to rip the seal. I slide the shaft through the body, then slowly slide the o-rings and spacers on the shaft. Next I'll use the black "washer/spacer" to gently push the seals into the cartridge.
NitroOB4You is offline
Old 07-28-2010, 04:19 PM
Thanks for the quick replies.. Will check em out..
Old 07-28-2010, 04:58 PM
Trader Rating: 14 (100%+)
Nice, thanks. Now i know what i was doing wrong. I was filling the shock, setting the rebound, then screwing the cap on with the bladder inside the cap. No wonder i was never getting the rebound i wanted.
DuckStang is offline
Old 07-28-2010, 05:02 PM
what effect does changing rebound have on the car with different rebound adjustments done?? eg, 1/2 rebound opposed to full or even 0 rebound??
Old 07-28-2010, 06:45 PM
Tony Newland's Avatar
Trader Rating: 53 (100%+)
use less rebound on loose/smooth tracks... more on high grip/bumpy tracks
http://www.youtube.com/watch?v=HNJy7kreK90
Tony Newland is offline
Old 07-28-2010, 11:10 PM
Play around with the amount of rebound you set. I like my shocks with half or no rebound. Others like full rebound. Depends on what you like.
Alan D. is offline
Old 07-29-2010, 03:57 AM
cluffy1's Avatar
i run a D8T and i use 0 rebound. this seems to keep the car more stable and predictable. if i use 100% rebound then the car is more responsive but is harder to drive consistantly.
cluffy1 is offline
Old 07-29-2010, 05:17 AM
Trader Rating: 32 (100%+)
I always thought it was less rebound smooth/highgrip and more on loose bumpy
mcion is offline
Old 07-29-2010, 09:09 AM
Less rebound will create alittle more traction, thats usually not needed on a high bite track.
More rebound on a rough track will keep the car on top of the bumps rather than following every one and getting caught up in them and eventually rolling. rebound will also help the car jump and land on rough tracks.
Old 08-01-2010, 07:40 PM
[fail]'s Avatar
this is right.
[fail] is offline
Old 03-20-2018, 04:13 PM
JaysonBlack's Avatar
I've ben told another effect of rebound is the initial rebound off of a jump. Aparently a faster rebound will help[ the car spring into the air a little more. Dunno.
JaysonBlack is offline
