Old 07-29-2010, 07:52 AM   #46
Default ?
Interesting comments by alot of poeple, I've worked with data acquisition and sensors and calibration for some years, and have seen pros and cons on temp guns/lasers. I use the PE-3, which I've done back to back comparisons with the Exergen, and found it only 1-2 degrees difference. I mostly une by smoke and engine response. The Exergen is a high quality temp gun, is it worth it, thats a matter of opinion, dirt and batteries will fault the best temp gun. I will say that the guys who use the red laser as a target, you can get a bad reading, since the infared sensor is not in the same location, you can see buy the infared photo attached.
akiyama77 is offline   Reply With Quote
Old 07-29-2010, 04:24 PM   #47
Trader Rating: 32 (100%+)
Default Exergen
By far the exergen is the best and most accurate. I had a brand new ofna mini temp gun I received from RC driver magazing. It was 50 degrees off, no joke. I had a raytek that seemed pretty good but I had a problem with the laser staying on while it was in my tool box. Nothing would even be touching the trigger. I bought a cheap one from harbor freight, it was just like the PE little grey ones with a stop watch and clock etc.. And it was ok, but I bought a used exergen for $150 and it is dialed. I use it for my electrics, as well as temping the track for tire selection. If you race 2 or 3 rc cars then buy an exergen and it will last forever.
Steven Sanchez
Hotbodies- 1/8 Scale World Champions•Viper R/C Solutions•Jconcepts-World champion bodies & tires• Dialed Inc- R/C car bags & Accessories •SIDEWINDER Racing Fuel•Kal-Gard- Racing lubricants & cleaners•
sider662 is offline   Reply With Quote
Old 07-29-2010, 05:14 PM   #48
Trader Rating: 29 (100%+)
to me i think every temp gun, whether you get a cheap 30 dollar one or s more expensive one, will be right around what the exergen reads. but the thing is, after a little bit, that cheap 30 dollar one will start to read worst and worst the more you use it. the exergen will read the same thing for a way longer time than the cheap ones.
kyosho mp9:novarossi 21-4C, nova 2084, 7955TG, dx3R
slayyer is offline   Reply With Quote
