Old 07-28-2010, 06:52 AM   #1
lewis666's Avatar
Send a message via MSN to lewis666
Default clutch bell problems?
hi there,
i need some help quick!!
i have now finished running in my new radical engine and i have fitted the clutch shoes and everything else but the clutch bell.
i normally put two shims in front of the clutch nut and two in front of the clutch bell. but for some reason there is 2-3mm of the shaft sticking out? here is a pic (sorry about useless quality)
i think the flywheel is to close to the engine? should i put some washers behind the collet so the flywheel will move forwards?
everything on the clutch is standard. could the clutch spacer be the problem? i am using the standard one but it seems to have abit on the bottom that fits into the bearing?
any suggestions?
many thanks in advance
lewis
Durango DEX410R, BCE Losi 8ight 1.5 (radical 621t), Durango DESC410R on the way!
radical engines- www.gotnitroonline.com
Got nitro team driver
lewis666 is offline   Reply With Quote
Old 07-28-2010, 06:56 AM   #2
jamiekerr14's Avatar
Yes your right you need to shim out the flywheel collet.. think most try to do it so there is 1-2mm to play with if all tightened down ect so you can shim to your liking on the bell..
Xray XB4
Supported By:
RC Disco
jamiekerr14 is offline   Reply With Quote
Old 07-28-2010, 06:57 AM   #3
lewis666's Avatar
cheers for the help.
how many shims should i put on?
many thanks
lewis
Old 07-28-2010, 06:59 AM   #4
Um your best bet would be to get some callipers and measure how much you need to move the flywheel ect forward. And shim that amount, or the more timely way is to do 1-2 tighten down put on everything and check.. and add more if needed.. calliper way is the best bet buddy..
No worries, hope it helps!
Xray XB4
Supported By:
RC Disco
Old 07-28-2010, 07:04 AM   #5
lewis666's Avatar
i will give it a try thanks
lewis
Old 07-28-2010, 07:05 AM   #6
No problem, will let you decide how much of a gap to leave as everyone has there own opinions on how much to shim or not.. if not sure do some searching
Xray XB4
Supported By:
RC Disco
