Old 07-28-2010, 05:01 AM   #1
Default crunching noise on car? help
hey guys mycar is playing up when i put the car on the ground to go it stalls, and when i hold t in the air the car makes a crunching noise and sounds like it coming from the brakes or gearsor something, im new to nitro cars and dot know much and im only 14 aswell
marto1996 is offline   Reply With Quote
Old 07-28-2010, 07:08 AM   #2
VWVR6_T's Avatar
Send a message via MSN to VWVR6_T
Take a look at the diff, make sure you have oil in it and once you at it look at the gears. Check the bearings are not lock. When was the last time you did any maintenance?
TLR 8ight 2.0 - Werks B5/2058 l Airtronics l Hitec l rev-rc.com l Werks Fuels l Sweep
TLR 8ight T 2.0 - Werks B5 Pro/2013 l Airtronics l Hitec l rev-rc.com l Werks Fuels l AKA
Ofna GTP l Hyper 8P Turbo
QUOTE by FLHX1550 "The Werks B5 is kind of a legend"
VWVR6_T is offline   Reply With Quote
Old 07-28-2010, 12:52 PM   #3
SpraydbySprague's Avatar
Location: Conducting aggressive board meetings at my local track
Trader Rating: 64 (100%+)
Check the clutch bell on the motor.
How would I describe my holeshots?
Three words...
Ready... Steady... Confetti!!!! (gonna need a new one of those)
SpraydbySprague is offline   Reply With Quote
Old 07-28-2010, 02:46 PM   #4
RUNNINONMT's Avatar
when you roll it back a forth on the ground by hand does it make the crunching noise? if its really hard to roll then you have something binding you'll have to start taking thing off to find where it is start with the tires then motor the drive shafts then you can check each diff at a time till you find what needs t o b e repaired
RUNNINONMT is offline   Reply With Quote
Old 07-28-2010, 03:47 PM   #5
bigjayjay1's Avatar
Trader Rating: 86 (99%+)
Is your kit new pre assembled or did you buy it used. Get a manual and read through the whole thing from your posting it sounds like you have a mesh problem. Mesh is clutch bell (Front of motor) and Spur gear (Center Differential).
You tube > RC nitro Mesh you should get some hits and pointers. Again read the manual don't be afraid to break down you kit and reassemble that's how you learn do it in sections and place the parts / organize them so you have a reference point.
TEAM: SERPENT AMERICA DRIVER -ADVANTAGE RACING PRODUCTS-COMPETITION HEAT INC - HOBBYPRO, VPPRO - BCE-
Serpent: 811N, 811T, 811E
bigjayjay1 is offline   Reply With Quote
Old 07-28-2010, 04:52 PM   #6
99problems's Avatar
Clutch bearing!!
Don't be a "CYBER BULLY" bring it to the TRACK!!
POINT and PULL!!
99problems is offline   Reply With Quote
