JQ Products - THE Car
#9496
#9497
Are you in belgium? Why dont you buy locally?
#9498
#9499
These guys have the power to help you:
Merlin Solutions v.o.f.
Het Menkveld 24,
7232GD Warnsveld,
The Netherlands
Tel: +31553666482
Email: [email protected]
Website: http://www.merlinsolutions.nl/
Het Menkveld 24,
7232GD Warnsveld,
The Netherlands
Tel: +31553666482
#9500
Het Menkveld 24,
7232GD Warnsveld,
The Netherlands
Tel: +31553666482
Het Menkveld 24,
7232GD Warnsveld,
The Netherlands
Tel: +31553666482
I called JEModels and they will have more JQ parts in a near future so I hope to find parts more easily
#9501
http://www.gbmodelsport.co.uk/contactus.php
if you look there it is a list of all the uk shops that stock JQ products if you cannot get in your own country.
#9503
guys just a quick question. I'm busy getting my EPA's right and setting brakes and stuff. i notice that in my case the servo has to pull quite hard for the brakes to actually do something....i usually dont like the servo to flex itself or the battery tray when setting up brakes but in this case im not getting enough stopping power...and i even shimmed my "pads" so that there is like only a hairs worth of play between them and the disk..not 0,5mm. Do you guys run the stock brakes on the JQ or upgraded ones...or do these become better as they warm up or something? im just scared of premature servo failure. i did not have this issue on my mugen.
#9504
Coming from losi to the the JQ I was worried by this at first also. However I quickly found it was not a issue. I actully ended up adding more EPA for my orriginal numbers were to conservative.
#9505
Can someone advice me good springs for high bite tracks?
I'm mostly driving on astroturf and high bite clay with few bumps/ jumps.
It can be from any brand I just need an alternative to my stock JQ V1 springs set
#9506
i guess any brands Harder springs should do...i can say that mugen springs dont fit the JQ, they are too long. im not sure about others though
#9507
#9508
#9509
spring are compatible but if you run the upper hole in the rear hub you will never get the ride height using the rear black springs.you could get the front springs and run them on the rear.
#9510
I really like the new blacks on the electric JQ.
