JQ Products - THE Car
#7366
Either through the above website, or you can try messaging him on here:
http://www.rctech.net/forum/members/grizz1.html
He's the man when it comes to anything GO related.
Or email address: [email protected]
#7367
Yes, the clutch is really good. Shoes last about 2-3 gallons depending on springs and you won't have any problems with installing the shoes.
As for the JQ oils, they aren't out yet and I wouldn't hold your breath waiting to build your kit because of the oils. Might want to get Losi 35 and 40wt shock oil, and another brand's 3k, 5k, and 7k diff oil.
#7369
Basically the car was very taily (due to the intial turn in generated by the the hubs. We also suffered some loss of drive out the corners
Aaron thought the car was faster but required you to be perfect at every corner, so this set up might be ok for qualifying but would be to hard to drive consistently over a longer race.
I might steer clear (pardon the pun) of the 12 hubs then, last thing I need is to be more taily!!
#7370
while waiting for the newer rods, a spanish driver suggests to use shorter screws, say 4x8mm or 4x6mm, instead of the 4x10 mm screws to secure the servosaver rods in the kits, this way the rodshafts can flex a fraction more on impact
and will likely break less easy
#7371
The track was very patchy that day there was quite few wet corners where the grip was over the top to (most) corners where there was none because of the recent rain.
But yes overall the car didn't look its usual rock solid self. Still thats what testing is about and after testing both the standard bubs (16 deree) and the 12 degree hubs we beleive the 14 degree hubs would be the the ducks guts!!!
Cheers
Mark
#7372
The oils in the Durango kits were misprinted. There was a zero too many on it.
2k in the front and 7k in the rear will have you do donuts with THECar all day. Vice versa makes way more sense, so it was most likely a mixup when he called the oils. Just get some Ultimate oils and you should be fine in terms of comparable digits on THE Setup-Page's sheets.
#7374
Mark
what is the reason you go higher on antisquat insert +1
on the overdrive set-up page ?
#7375
Got a JQ car roller with 1 tank (yes 1 tank) of fuel thru it
bought a losi truggy/buggy of a friend and running them now
comes with de skids/bumper
m2c hingpins in package
literally like brand new, was bought/built 1 week ago
$280 and i will cover shipping
see my for sale ad or pm me
can send pics to any1 interested
#7376
Does the Ofna blue truggy box work with THE Car?
Am using the GO box at the moment, but cant use any alignment pegs as the way the pegs are mounted, it lifts the buggy to high to make contact with the flywheel. I can start it, but TBH its a pain in the ass having to line it up manually every time.
Any other common boxes that anyone can reccomend?
#7377
#7378
And I'm not getting MY Car until tuesday
#7379
#7380
We have been playing around a bit with the anti-squat since putting in the overdrive.
It seems to suit the way overdrive works. Once again it was more a feel thing for us than anything else.
Cheers
Mark
