Old 07-27-2010, 04:18 AM   #1
Default Needing flywheel, collet & other stuff for my new engine.
I have a LRP zr.30 spec 2 for my LST. I've decided on a 4 shoe competitive clutch setup but I'm at a loss for finding the collet, shimms, flywheel and other things needed to complete the setup(I know which clutchbell of course).
Any info is appreciated.
BaldNitroJunkie is offline   Reply With Quote
Old 07-27-2010, 04:49 AM   #2
Trader Rating: 15 (100%+)
I'm confused here!You already have 4 shoe's but no flywheel?Either way you need to buy a 4 shoe set-up which comes with a flywheel.You can use any collet and if you go to nitrohouse they sell a shim kit that has pretty much every shim you'll need.Hope this help's
Mugen 6T/ powerhouse modded toro nere' plus 4 ' p5xs / hot modded FMS / The sleeper 821B
.Sponsor's Mr Jingle's super flame out race fuel/
Should work glow plug's/mynutzyourchin racing tire's.I'd like to bring on my new sponsor's ballzydick servos & onehunglow ball ends and puffy pack lipo company.I couldn't do it with out you guy's
blacksunshine is offline   Reply With Quote
Old 07-27-2010, 05:46 AM   #3
Ahh grasshopper sees it now. The 4-shoe clutch kit has the flywheel that is needed for it already. I take it the driveshaft size got most nitro engines are all the same diameter?
Old 07-27-2010, 08:06 AM   #4
Only now can grasshopper jump over the tall grass.Your search for the answers have been fruitful.Hopefully grasshopper is using at least a 14t clutch bell or he shall have a stump puller with no top end.Is grasshopper using a starterbox?If so one should make sure the flywheel is big anough to reach the rubber wheel.If not you can make the slot on the chassie longer so the rubber wheel can get to the flywheel.Let us know how it turns out.
