Old 07-27-2010, 08:14 AM   #31
Akhor's Avatar
Check your bearing on the rear diff. If they are shot it will cause the whole diff to move and screw up your shimming and everything.
--Blaine--
VBC D07, VBC D08
Mugen MBX 7, Mugen MBX 7 Eco,Mugen MBX 7r, Mugen MBX 7r Eco
www.rcgears.net, www.carcar.ca, www.karz.ca
Akhor is offline   Reply With Quote
Old 07-27-2010, 09:24 AM   #32
KThatcher's Avatar
Trader Rating: 64 (100%+)
The best way to check your ring and pinion is to grab rear driveshaft with pliars or something that wont give.. then grab both tires at the same time and try to spin them foward with a little pressure. If it clicks and skips gears either the ring or pinion is toast..(most of the time its both) You should replace both at the same time anyways as you dont want to put a new pinion on a worn ring gear or vice versa. I also replace the diff case, bearings and put new shims on (shim how it shows in Losi instructions) I also run the Losi Rear Gearbox Bearing Inserts http://www.losi.com/Products/Feature...rodId=LOSA4454
when you replace gears make sure to put alot of grease on them I run mobile 1 synthetic.
- Picco - Triton RC - 818 Designs - Team-CRP - RCRenew.com -
Pro Motion T-shirts -
KThatcher is offline   Reply With Quote
Old 07-27-2010, 10:06 AM   #33
segui305's Avatar
Send a message via Yahoo to segui305
Originally Posted by petevette View Post
If you have it shimmned correctly and it still makes the noise then your ring and pinion have too much wear. Look me up at the track this Saturday and I will try to give you a hand - although I am no expert but I was able to fix mine. If not, I will pit you in touch with one of our resident Losi experts to take a look at it.
thanx!! i would really appreciate that but im pretty sure that i wont be able to go this saturday bc its my g/f birthday.
Team Losi 8ight 2.0 buggy- Proline- j concept- Futaba 3pks Spektrum module- hi-tec servos- jr9811-Dynamite Mach .21-OS VZB V-SPEC .21-Team Str8 killaz
segui305 is offline   Reply With Quote
Old 07-27-2010, 10:41 AM   #34
segui305's Avatar
i already check the bearing and they all move freely and they look good. maybe that Losi Aluminum Rear Gearbox Bearing Inserts will do the trick, i will probably replace the pinion and ring
Old 07-27-2010, 06:06 PM   #35
segui305's Avatar
Old 07-28-2010, 01:53 AM   #36
Ask Bart to intro you to Gil. If he can't fix it, the dumpster at the back gate can.
The Working Man is offline   Reply With Quote
Old 07-28-2010, 06:45 AM   #37
segui305's Avatar
i might just take your advice and toss it the big green garbage dump. damn slowsi lol
Old 07-30-2010, 05:20 PM   #38
trackstarlosi's Avatar
yeah! fuck that car, its totally the cars fault u cant shim. haha wow
Dylan Elliott
TLR Team Losi Racing / Novarossi / Nitrotane / Spectrum
trackstarlosi is offline   Reply With Quote
Old 07-30-2010, 06:00 PM   #39
dishsoap's Avatar
Wow great language and we wonder why there are very little sponsored drivers that come onto to this site to give a helping hand.
I dont blame them!!!!!!!!!!!!!!
HobbyTown USA Tucson!!! HobbyTown USA SRS!!!!
dishsoap is offline   Reply With Quote
Old 07-30-2010, 06:40 PM   #40
i explained how to shim it and what went wrong one page back, and he just wants to throw it away... didnt mean for anyone to take it as serious as you.
Dylan Elliott
Old 08-01-2010, 07:12 PM   #41
petevette's Avatar
Send a message via Yahoo to petevette
Yep, I was thinking of Gil as well. He is the Losi king at our track. He diagnosed my car before I finished explaining the symptoms.
BTW, if you decide to chuck it in the dumpster, let me walk with ya when you do it.
petevette is offline   Reply With Quote
Old 08-01-2010, 07:53 PM   #42
segui305's Avatar
dude i was only kidding about tossing my car into a dumpster. i am new to this hobby but im willing to ask question and learn from my mistakes. it still making the noise when i brake but i haven't bought new pinion and ring. i will order some shortly.
ive also notice that my front diff housing keeps cracking by the tower shocks, has that ever happen to any of you???
Old 08-01-2010, 08:08 PM   #43
dishsoap's Avatar
Dude will you just add some more rear break and try it. On the linkage twist it clockwise. Keep twisting it a good amount and see what happens.
Old 08-01-2010, 08:12 PM   #44
petevette's Avatar
I know you were kidding, it was just fun chatter. Hey, you coming out this Saturday?
Old 08-01-2010, 08:22 PM   #45
segui305's Avatar
yea i did, the more rear brakes i put the more sounds it makes. that was the first thing i did to see if that was the problem.
Alex Racing Barracuda R2 & R3 SpeedTech Electric On-Road 14383 08-21-2014 06:06 PM
