Old 07-25-2010, 05:19 PM   #16
808gx7r's Avatar
Originally Posted by segui305 View Post
i know for a fact the noise is not coming from my brakes because what i did is i took the rear off from the car and got a towel and held the drive shaft, got both tires drag them on the floor and it was still making that cracking sound.
if what you said here is true its your pinion meshing to the diff ring
808gx7r is offline   Reply With Quote
Old 07-25-2010, 10:07 PM   #17
Frank L's Avatar
Trader Rating: 148 (100%+)
My 2.0t Lways makes noise on power. No matter how I shim it, it still always sounds like it's going n ew gears same just not as loud.
Old 07-25-2010, 10:09 PM   #18
CJ Weaver's Avatar
Send a message via AIM to CJ Weaver
Ring and Pinion
RCAmerica | Team Xray | Hudy | JConcepts | Kal-Gard | KO Propo
Novarossi | Fine Line Design | ProTek RC | Byron Fuels | Team Tekin
Vinyl Graphics Unlimited | A-Main Hobbies | A-B Charles Hobby Shop
CJ Weaver is offline   Reply With Quote
Old 07-25-2010, 11:55 PM   #19
Trader Rating: 14 (100%+)
Meh, I would check the rear shaft right at the coupling. My was doing the same thing, turned out to be the pins in the shaft got worn and was binding up. Another thing that i saw was the coupling that attaches to the pinion, it has a set screw, check that. Saw a guy at the track with the same problem, loose set screw backed out enough it was slipping over the flat part on the pinion making a bunch of noise. Don't jump to the conclusion that it's the diff.
Just make double sure it's not the pads. Reason i say this, well, 2 days ago this thread and my thread would have had the same title.
The hole in my brakes were worn and it was causing it to wobble where it would touch the brake pad screws.
DuckStang is offline   Reply With Quote
Old 07-26-2010, 07:13 AM   #20
segui305's Avatar
Send a message via Yahoo to segui305
Originally Posted by Jammin57 View Post
It is the rear diff, if it has done it alot replace the ring and pinion gear and the bulkhead
does that happen alot with losi???
Team Losi 8ight 2.0 buggy- Proline- j concept- Futaba 3pks Spektrum module- hi-tec servos- jr9811-Dynamite Mach .21-OS VZB V-SPEC .21-Team Str8 killaz
segui305 is offline   Reply With Quote
Old 07-26-2010, 07:45 AM   #21
rfleck's Avatar
Trader Rating: 58 (100%+)
Yes, if the rear diff on the 8t is not shimmed properly it will have issues.
Ron Fleck Jr.
Nemoracing USA!
Agama-Beta-Bullitt!
rfleck is offline   Reply With Quote
Old 07-26-2010, 08:22 AM   #22
segui305's Avatar
actually it might be the pinion. it looks a little funny!!!
Old 07-26-2010, 09:20 AM   #23
Frank L's Avatar
Any car that's not shimmed correctly will blow the ring and pinion. I think losin owners got use to the 1.0 where you didn't have the option to shim the ring and pinion and they just don't do it correctly.
Old 07-26-2010, 11:07 AM   #24
segui305's Avatar
yea ill go home and see if putting some shimmed will fix the problem.
Old 07-26-2010, 10:20 PM   #25
petevette's Avatar
Send a message via Yahoo to petevette
If your getting a clicking sound then it is caused because of shimming. Have you been out to the mills pond track? There are a lot of guys there that know that car inside out and could help. I had that problem with mine but after I reshimmed it all was good.
petevette is offline   Reply With Quote
Old 07-26-2010, 10:25 PM   #26
segui305's Avatar
yea i was there this pass weekend. the only time i hear the cracking noise is when i start to brake hard. today i places shimmed and the noise still happens when im braking hard.
Old 07-26-2010, 10:32 PM   #27
trackstarlosi's Avatar
incorrect shimming, replace the ring and pinnion and put back together with two shims on each side.
Dylan Elliott
TLR Team Losi Racing / Novarossi / Nitrotane / Spectrum
trackstarlosi is offline   Reply With Quote
Old 07-26-2010, 10:49 PM   #28
Ring/pinion is skipping under braking. If you don't know what shimming is then it's safe for me to say "your not shimmed." And, that's your problem.
If you were shimmed it could be the diff case or outdrive bearings. More often than not this happens due to bearing failure allowing the diff to shift inside the case under loads.
I had the same symptoms, and, like you I thought it was the brakes. It gradually got worse over time. After inspecting, the ring gear side bearing had a lot of play in it. I don't care how good you are at shimming a bearing that bad is going to cause gear damage.
I'm going to try ceramic f/r diff bearings. I hope they hold up longer because mugen ring/pinions are not cheap. Nor are losi's.
trackstarlosi incorrect shimming, replace the ring and pinnion and put back together with two shims on each side.
Really? Two on each side? Losi really has some diff case issues then.
Franchise is offline   Reply With Quote
Old 07-27-2010, 01:20 AM   #29
808gx7r's Avatar
i have a xray 808. and i have never shimmed a diff in my life... life's great with xray.
Old 07-27-2010, 07:13 AM   #30
petevette's Avatar
If you have it shimmned correctly and it still makes the noise then your ring and pinion have too much wear. Look me up at the track this Saturday and I will try to give you a hand - although I am no expert but I was able to fix mine. If not, I will pit you in touch with one of our resident Losi experts to take a look at it.
Alex Racing Barracuda R2 & R3 SpeedTech Electric On-Road 14383 08-21-2014 06:06 PM
