Old 07-25-2010, 12:29 PM   #1
Trey7's Avatar
Default diff leaking?
I was curious if I am the only one having a problem with the diff fluid seeping out where your diff cups go into the diff. I have replaced the seals on the cup and inside the diff but still it will seep out after sitting for a couple days. I run the rc8t and have been using the stock seals. are there any better seals that I could use or something I could try to resolve this problem. The diff cups are also new. Thanks
Hobby Pro USA, Beta Tires, VP-PRO-USA, Werks Racing, Team Associated, Savox
Trey7 is offline   Reply With Quote
Old 07-25-2010, 01:04 PM   #2
ur probably doing something wrong. if it leaks out in a few days...u might of stripped out the dif screws...if not...try rtv all non moving seals
killerkoolaid is offline   Reply With Quote
Old 07-25-2010, 01:16 PM   #3
bboard's Avatar
Are you greaseing the o-rings? If not rub them with AE 'Green Slime'
Hotbodies D8-Werks B6/2057-Byrons-Orion LiFe-HiTec Servos-Airtronics M11 2.4
bboard is offline   Reply With Quote
Old 07-25-2010, 01:43 PM   #4
Trey7's Avatar
I do grease all my seal with associated green slime, and my diff screws are not stripped. If it was the screws being stripped then the fluid would be leaking from between the ring gear and not there the where the diff bearing are located.
Old 07-25-2010, 02:49 PM   #5
Slider30250's Avatar
Only fill your diff cups up till the oil just barely reaches the top of the spider gears. If you have any oil seep out from the screw holes or gasket when you cap the diff with the ring gear then you have filled it too much.
Anyone can crash, I crash with style
Mugen MBX6R/Airtronics M11X/Ninja Engines/Sidewinder Fuel/EB Mods
Slider30250 is offline   Reply With Quote
Spec-R Gear diff review P.I.M.P Electric On-Road 890 08-31-2013 04:16 AM
Losi Smart Diff Frank L Nitro Off-Road 580 06-25-2013 11:01 AM
Gear Diff VS Ball DIff NOVICE4EVER Singapore R/C Racers 23 08-29-2012 09:03 PM
