Old 07-23-2010, 10:08 PM   #1
ele_to_nitro's Avatar
Questions?? bougging
i have a traxxas nitro rustler with a trx 2.5 and after i gets up to temp it starts to boug and it no longer starts accelerating sharply and top end is limited to like 25 or 20 mph in stead of 50+ and including break in it only has 1 1/4 quarts of fuel so if you know tell me and this is my first nitro car so i am not very experianced.
ele_to_nitro is offline   Reply With Quote
Old 07-23-2010, 10:11 PM   #2
Cory Kerber's Avatar
What does it do while it's getting up to temp? As it warms up it should lean out, so it sounds like you've got a lean bog. But, since it's a new engine it may have "dropped it's nuts"(goes way rich). I doubt that though since it's only got 1 quart through it.
Losi 8ight-Novarossi N21R-Hitec Servos-AKA-M11 Spektrum
*TEAM TERRIBLES*
Cory Kerber is offline   Reply With Quote
Old 07-23-2010, 10:18 PM   #3
when it gets up to temp it runs fine its alittle slow although and it doesn't even get a wheelie in the blacktop in a straight line when it gets to temp and i'm running at 207/ 210 degrees when it does bog so im very confused.
Old 07-23-2010, 10:41 PM   #4
Does it spit and sputter with alot of smoke when it bogs?
*TEAM TERRIBLES*
Old 07-23-2010, 10:47 PM   #5
non of any of those and i know it should have blue smoke with it
Old 07-23-2010, 10:48 PM   #6
Try richening each needle 2 hours and see if that helps.
*TEAM TERRIBLES*
Old 07-23-2010, 11:01 PM   #7
Too lean on the HSN and too rich on the LSN. These are finicky little engines, very small adjustments on the LSN. I don't know what fuel you are using but Traxxas fuel is poo. It will run better on a good quality 30% fuel like Byron's Race blend. You want a fuel with no more than 12% oil. Oil causes excess heat and makes a false tune condition more likely.
I had great luck with Trinity MHP 30% fuel in my TRX mills.
You need to start with a fresh glow plug too, you more than likely have distorted your current plug from running the engine lean and too hard too soon. It will not run right with a distorted plug. It will be impossible to tune.
Kyosho ST-RR, with full lightweight treatment.
JL .21 Extreme RC Modifed
Backup; Trinity Fully "Draked" .21, 7 gallons and counting!
Futaba 3PM-MX, Hitec and JR digi's
VP-Pro tires
ScroggJL21 is offline   Reply With Quote
Old 07-26-2010, 03:46 PM   #8
20% byron race fuel and what do you mean by 2 hours for the needle? but i apreciate the help
Old 07-26-2010, 04:34 PM   #9
On the low speed needle, located at the end of the carb slide, turn it clockwise 2hours or 10 minutes as it would read on a clock.
*TEAM TERRIBLES*
