Old 07-22-2010, 07:14 PM   #1
Default do I need to switch to lipo
I've been running a 1600 and 1900 nimh hump packs. I've never had any trouble with them, but I've entered my first big race and I'll probably be in either a 45 or 30 minute main.
I'm adding a 7955 servo and an rc4 transponder to the mix. Both are going to use more juice then what I was using before. Am I going to be able to run long mains with just normal Nimh packs, or am I going to have to make the switch to lipo? I really don't want to switch, but if lipo is really needed I can.
And if I can stick with Nimh packs do I need to go bigger then 1900?
bevofrancis is offline   Reply With Quote
Old 07-22-2010, 07:20 PM   #2
dandrat's Avatar
no need to switch. if you have a fresh nimh for the mian you will be fine.
dandrat is offline   Reply With Quote
Old 07-22-2010, 07:21 PM   #3
That's what I wanted to hear.
Old 07-22-2010, 07:22 PM   #4
Quad Racer 34's Avatar
Trader Rating: 4 (83%+)
They should last. I just got a Reedy lipo pack. I ran about 10 min in practice then 3 qualifiers and decided to top it off before the main and it only charged less than 400mah. It's nice having the lipo in there. You might want a regulator as well.
Dylan Gerard
Serpent - Desoto Racing - Picco - AKA - Hitec - RC Addictions Products - Tekin - VRP - Avid RC - SMC - MIP - SkipGear - The Ohio RC Factory
Quad Racer 34 is offline   Reply With Quote
Old 07-22-2010, 07:26 PM   #5
If I went lipo what all do I need? I don't know anything about them.
Old 07-22-2010, 07:37 PM   #6
DezSlash's Avatar
You'll need the lipo, a regulator and a compatible charger. I use a common sense rx battery and the reedy regulator. I have 2 hyperion charges that i maintain all the batteries with.
Companies I support
Hot Bodies*Futaba*Novarossi*JConcepts*Hitec*Upgrade Rc*Kalgard*Sidewinder Fuel*Dialed
Arcor Raceway
DezSlash is offline   Reply With Quote
Old 07-22-2010, 07:39 PM   #7
Is this all I would need to go lipo.
http://www.amainhobbies.com/product_...0C-74V-2100mAh
http://www.amainhobbies.com/product_...tor-w-o-Switch
http://www.amainhobbies.com/product_...ng-Bag-23x30cm
http://www.amainhobbies.com/product_...rger-4S-6A-80W
I wasn't sure about a bag, but it seems like I read that tracks are starting to require lipo charging in in a bag.
Old 07-22-2010, 07:42 PM   #8
Those are what you need. I'm not sure about the bag for the state race. I haven't heard anything about needing them. But that lipo is good. Muchmoore has a regulator for 15 bucks. Little cheaper than that losi one.
this one. I have it works good.
http://www.amainhobbies.com/product_...tage-Regulator
Dylan Gerard
Old 07-22-2010, 07:43 PM   #9
DezSlash's Avatar
I dont use a bag for the rx battery since i charge it in the car. Most of the time i charge the nite before. i use this regulator.
Companies I support
Arcor Raceway
Old 07-22-2010, 07:47 PM   #10
That's the one I looked at but it's out of stock. I hate to mix a losi regulator with an associated battery. Losi might try and sabotage me, but that's the only other cheap one I seen.
Old 07-22-2010, 07:49 PM   #11
dandrat's Avatar
you can still run nimh, can switch to lipo or run LIFE which is probably better. your choice of course.
Old 07-22-2010, 07:57 PM   #12
I run nimh and ran a 30 min main with a fresh 1600mah. No Problem. Using JR 9100s and T and an amb transponder.
bacchus is offline   Reply With Quote
Old 07-22-2010, 08:04 PM   #13
I'm just kind of checking out my options, and seeing how much it would cost to make the switch. It's looking like it's a pretty expensive switch. I'll peobably stick with what I have for now. Maybe do some testing this weekend and see how long i can run non stop before my 1900 dies.
Old 07-22-2010, 08:13 PM   #14
Make sure you have a strong throttle return spring if you are going to run it till it dies!
Dylan Gerard
Old 07-22-2010, 08:22 PM   #15
Cory Kerber's Avatar
If you're running dual 7955's you can run unregulated lipo. Unless you're running the FASST radio system.
Losi 8ight-Novarossi N21R-Hitec Servos-AKA-M11 Spektrum
*TEAM TERRIBLES*
Cory Kerber is offline   Reply With Quote
Switch to LiPO, hot motor mfs Radio and Electronics 7 04-13-2010 06:08 PM
Bout to buy a slash. What kind of batteries do I need jfd152 Electric Off-Road 7 11-20-2009 07:00 AM
Most cost effective way to switch to lipo? xlgraphicspro Nitro Off-Road 6 05-21-2008 06:40 AM
Making the switch to lipo Tree Nitro Off-Road 15 04-11-2008 10:25 PM
