do I need to switch to lipo
I've been running a 1600 and 1900 nimh hump packs. I've never had any trouble with them, but I've entered my first big race and I'll probably be in either a 45 or 30 minute main.
I'm adding a 7955 servo and an rc4 transponder to the mix. Both are going to use more juice then what I was using before. Am I going to be able to run long mains with just normal Nimh packs, or am I going to have to make the switch to lipo? I really don't want to switch, but if lipo is really needed I can.
And if I can stick with Nimh packs do I need to go bigger then 1900?
They should last. I just got a Reedy lipo pack. I ran about 10 min in practice then 3 qualifiers and decided to top it off before the main and it only charged less than 400mah. It's nice having the lipo in there. You might want a regulator as well.
You'll need the lipo, a regulator and a compatible charger. I use a common sense rx battery and the reedy regulator. I have 2 hyperion charges that i maintain all the batteries with.
Is this all I would need to go lipo.
http://www.amainhobbies.com/product_...0C-74V-2100mAh
http://www.amainhobbies.com/product_...tor-w-o-Switch
http://www.amainhobbies.com/product_...ng-Bag-23x30cm
http://www.amainhobbies.com/product_...rger-4S-6A-80W
I wasn't sure about a bag, but it seems like I read that tracks are starting to require lipo charging in in a bag.
Those are what you need. I'm not sure about the bag for the state race. I haven't heard anything about needing them. But that lipo is good. Muchmoore has a regulator for 15 bucks. Little cheaper than that losi one.
this one. I have it works good.
http://www.amainhobbies.com/product_...tage-Regulator
I dont use a bag for the rx battery since i charge it in the car. Most of the time i charge the nite before. i use this regulator.
I run nimh and ran a 30 min main with a fresh 1600mah. No Problem. Using JR 9100s and T and an amb transponder.
I'm just kind of checking out my options, and seeing how much it would cost to make the switch. It's looking like it's a pretty expensive switch. I'll peobably stick with what I have for now. Maybe do some testing this weekend and see how long i can run non stop before my 1900 dies.
