i want to rebuild my losi 8ight 2.0 >
Old 07-25-2010, 11:42 AM
  #16
mudboger07's Avatar
Originally Posted by inferno13
question.....................you say hammer out dents? how do you do that without makeing more dents? just wondering, i have a 086 witha small dent and want to know how to fix it, thanks
The freezer works ok for taking dents out of a pipe. Plug one end of the pipe and fill it with water, Put it in the freezer, check it often. The freezing water will push the dent out. You can also try an air compressor if you can get a good seal..
mudboger07 is offline
Old 07-25-2010, 11:58 AM
  #17
Suspended
Trader Rating: 202 (96%+)
great idea!!!! would have never thought of that!!!! ill try the compressor first, thanks!!! ill try the freezer if that doesent work, but will wait till the wife is gone!
inferno13 is offline
Old 08-05-2010, 06:27 AM
  #18
segui305's Avatar
-stripped threads/worn screws/rusted screws
-stripped threads in plastic parts
-cracked, sloppy-fitting or severely worn plastic parts
-gear mesh/condition of gears
-hinges should be free-moving, little slop and not bent
-shock shafts/replace shock O rings & oil
-bearings should be free and not notchy or scratchy when turned
-replace main chassis if bent/severely worn/cracked
-rebuild CVDs; replace worn pins and if necessary, worn drive cups
-check/replace worn shock springs (they lose tension over time)
-inspect clutch, de-burr shoes, keep inside of bell free of aluminum buildup
-inspect pipe for obstructions/oil buildup; hammer out dents as needed
-make sure pipe/header springs have sufficient tension; replace as needed
Is this the best list you guys recommend??????
segui305 is offline
Old 08-05-2010, 09:10 AM
  #19
bobbyblaze's Avatar
i would send to the speedshop..Alan do an excellent job , just my opinion
bobbyblaze is offline
