Old 07-22-2010, 12:01 PM   #1
Catch 22's Avatar
Default Rear diff question
I know this subject has been flogged to death but I have a question about the rear diff.
I understand diff action and tunning quite well . But I see people running setups with a very heavy rear diff in truggies and buggies .
If thinner diff oil improves rear traction and thicker oil decreases rear traction going into the corner , how does a heavy rear diff oil help ?
A couple of weeks ago I was running on an astroturf track and the rear end was skidding about all over the gaf (i was running 7f 7c 3r) . Someone suggested moving up to 5 or 7 in the rear. 7 in the rear really calmed the rear end down and made the car more drivable . Why did this work when a heavier rear diff should in theory have made it worse?
I then ran the same setup at a different track a week later which was also astroturf and the backend was loose again so I dropped to 2 in the rear and the back end was good again .
Whats going on?
Pete
Catch 22 is offline   Reply With Quote
Old 07-22-2010, 12:17 PM   #2
tiger200350's Avatar
Trader Rating: 11 (92%+)
Pete, I think it is one of those driving style things, track grip, and layout.
Buggy:
Truggy:
"I'm just a racer!"
tiger200350 is offline   Reply With Quote
Old 07-22-2010, 12:19 PM   #3
NitroFreakManHo's Avatar
Send a message via MSN to NitroFreakManHo Send a message via Skype™ to NitroFreakManHo
A heavier oil doesn't decrease traction, it increases it by sending more power to both wheels( like posi-track ) vs one wheel getting most of the power ( open-diff ), in effect giving you twice the traction..but the catch is this, if you are throttle happy and spinning your wheels from excess power, the 'posi effect' will tend to kick your car sideways more than an open-diff ( light oil ). Hope that makes sense.
TEAM TERRIBLES √ 2009/2011 SORRCC Points Series Truggy Champ
CRE Werks B5 powered Serpent 811-T
CRE Nova P5 Powered Serpent 811-B
**M2C**Hitec 7955TG Servos**Buku Clutch
www.apaarchery.com www.skoffroad.ca www.youtube.com/nitrofreakmanho
NitroFreakManHo is offline   Reply With Quote
Old 07-22-2010, 12:32 PM   #4
Catch 22's Avatar
thanks
I does make sense but the setup manuals etc say heavier = less grip. Astro has some crazy grip though.
Why did the heavier oil not work on the second track though when dropping down to 2 in the rear gave the rear loads more traction than the heavier oil ? was it because the second track had less grip ?
Even though the second track had less grip , it was still way more grippy than a dirt track would have been . its a little confusing , especially when the front and centre diffs are so easy to tune .
appreciating the help
Pete
Old 07-22-2010, 01:34 PM   #5
omarwashington's Avatar
The way i see it is that when using thicker/heaver oil in the rear, you loose traction in turns and corners, but you have lots of traction when going straight.
RCCARS!
omarwashington is offline   Reply With Quote
Old 07-22-2010, 01:58 PM   #6
Catch 22's Avatar
yeah this what i thought which is why it baffles me why heavier worked for me the other week on one track and was garbage on a similar track afterward . Also why some pros use really heavy rear fluid on dirt tracks . I would have thought the car would 180 all the time
Old 07-23-2010, 11:48 AM   #7
j_blaze14's Avatar
Trader Rating: 34 (100%+)
a lot of cars now have a lot less weight in the rear, sometimes theres not enough weight in the back to come around in a corner so a "looser" rear is needed or else you are stuck with the push. some tracks have a lot of sharp turns like 180's and some are a bunch of 90's. i've been running 777 in my rc8t since january and have always gone back to that after testing. shock weight and angle also affect rear traction.
aGama A8 EVO - Werks B2 - Sidewinder
aGama A8E - TrackStar 150a, 2560kv, 3 and 4 cell
FlySky GT3B, Turnigy HV servos, SKY Lipos
AKA, Proline, Hotbodies Rubber
Elite Performance - HORRC.com
j_blaze14 is offline   Reply With Quote
Slash rear diff question about adding fluid jnelson214 Electric Off-Road 17 03-14-2010 07:55 PM
rear diff question storytyme Electric On-Road 13 01-17-2010 05:28 PM
