Old 07-21-2010, 12:57 PM   #1
mkbbadd's Avatar
Questions?? Losi 2.0T
I need some help on shiming the rear ring and pinion,I shimmed it by the book and it didnt make it the whole main.CAN SOMEONE HELP!!!!!!!
Mike B. Losi Rules
mkbbadd is offline   Reply With Quote
Old 07-21-2010, 01:31 PM   #2
MikeFriery's Avatar
Trader Rating: 19 (100%+)
Shim it tighter. As tight as you can get it without it binding badly once you screw the diff case tight.
AKA / RedRock Hobbies / Shuurspeed
MikeFriery is offline   Reply With Quote
Old 07-21-2010, 06:07 PM   #3
steve307b's Avatar
Trader Rating: 23 (100%+)
First of all make sure your rear drive-line has no forward/back play on the pinion. You have to hold the pinion in with your finger when tightening the set screw on the driveline. Looking at the back of the truck ,I like to add a shim or two to the left side to bring the ring gear closer to the pinion, so there is not alot of play. Like the other guys said shim it tighter. I just built a new rear diff last week and shimmed it to where it was a little knotchy(or high spot) about a 3rd of the way around. I almost thought it was too tight, but from reading on here thats what works. good luck
8ight-T 3.0 **FX Royal Engine** 2013- Savox 1267/Hitec 7950
Henchman racing
DX4R
steve307b is offline   Reply With Quote
Old 07-22-2010, 07:09 AM   #4
Get a new diff case and shim to that in the instructions... Make sure to use the alum bearing holders.
TLR - Spektrum - Horizon - TLR 8ight 4.0 - TLR 8ight-T 4.0 - TLR 22 4.0 - Orion
token is offline   Reply With Quote
Old 07-22-2010, 10:35 AM   #5
JAMMINKRAZY's Avatar
Trader Rating: 17 (100%+)
Shimming it by the book WILL cause issues. It has to be tight, and I mean TIGHT! Like Mike and Steve said, shim it as tight as possible without it binding up. You will notice a bit of a high spot on the ring gear where it is a little notchy. This is perfectly normal. As long as it isn't locking up, you will be fine.
-Koby Kubrin-
Thanks to my Sponsors:
Serpent America | Team Novarossi | Desoto Racing | Race AKA | Ridgeway Bodies
JAMMINKRAZY is offline   Reply With Quote
Old 07-22-2010, 11:14 AM   #6
bigjayjay1's Avatar
Trader Rating: 86 (99%+)
This is what I do never looked back shimming from left to right looking towards the front.
Add one shim on the right starting shimming on ther left you will need to repeat this process a few times.
Keep shimming until it gets some what tight when it gets tight. I take the diff out and starting removing from the left adding to the right. I shim were the high spots get a tad notchty. The diff should have absolutely no play back and forth in the case it should be some what hard to place the diff
As Jam said buy the ALU inserts.
TEAM: SERPENT AMERICA DRIVER -ADVANTAGE RACING PRODUCTS-COMPETITION HEAT INC - HOBBYPRO, VPPRO - BCE-
Serpent: 811N, 811T, 811E
bigjayjay1 is offline   Reply With Quote
Old 07-22-2010, 01:44 PM   #7
mkbbadd's Avatar
Post
Thanks guys your info is going to be a big help!!!!!!!!!!!!!!!!!!!!!!!!!
Mike B. Losi Rules
Old 07-22-2010, 01:47 PM   #8
dude i brought the alum parts shimmed by the book and this is my second year with that shim.
Old 07-22-2010, 01:49 PM   #9
Toiffel's Avatar
Trader Rating: 52 (100%+)
+1
Esteban "BBQ" Baquero
Barry "Barely" Goodwin's worst nightmare.....
Toiffel is offline   Reply With Quote
Old 07-22-2010, 01:52 PM   #10
mkbbadd's Avatar
Post
YA, I have ran almost a year before having this problem and now I guess i wiil put in all new and try again!
Mike B. Losi Rules
Old 07-23-2010, 05:44 AM   #11
are you running the alum diff holders?
Old 07-23-2010, 06:00 AM   #12
Brushlessboy16's Avatar
Trader Rating: 18 (100%+)
Send a message via AIM to Brushlessboy16 Send a message via Yahoo to Brushlessboy16
Get the 1.0 Rear diff case aand shim it... I run a brushless 8ight T and haven't killed a diff yet.o
Ben White aka The Flyin' Flashlight
Rc-monster Team Driver
JQ The Car, Neu 1515 1.5D, Mamba Monster, Rc-monster slipperential, Futaba Bls351
Unconventional Techniques, Superior Results.
Brushlessboy16 is offline   Reply With Quote
Old 07-23-2010, 06:31 AM   #13
mkbbadd's Avatar
Post
Yes I am running the alum diff holders.
Mike B. Losi Rules
Old 07-23-2010, 07:41 AM   #14
Frank L's Avatar
Trader Rating: 148 (100%+)
I usually start with 2 shims on each side and then after a gallon or 2 put 3 on the left and 1 onthe ight to make it a little tighter.
Losi 2.0T roller, VERY NICE TRUCK!!!!! Trevor Williams R/C Items: For Sale/Trade 18 07-02-2010 08:59 AM
DIALED LOSI 2.0T SETUP ARTR, LOADED!!! Trevor Williams R/C Items: For Sale/Trade 18 06-23-2010 06:36 PM
$BIGSALE,mmp,pl slash4x4,dx3s, mm1600kv bl,losi 2.0t nib,$ david saechow R/C Items: For Sale/Trade 14 04-05-2010 12:07 PM
What needs to be done to the LOSI 2.0T RUF-VK Nitro Off-Road 26 07-25-2009 12:59 PM
>>>LOSI 2.0T ROLLER<<< G MIKE R/C Items: For Sale/Trade 8 06-14-2009 04:54 PM
