Flame Out after refueling
try this, make you pit guy shake you buggy a few time and it probably wont stall. i know it sounds stupid but it works! ive seen a few of the top pros like ryan cavalarie (check spelling) do it some time. its either that or you need to replace fuel tank or pressure line to the pipe.
Sometimes when I pit for someone too cheap to get a proper fuel gun or someone too lame to cut proper refueling holes in thier body I end up spilling fuel on their pipe. That allways seems to cause a flame out on the way out of the pits.
Usually I need to richen my low end a tad or come in 1 lap sooner when this happens to me. Maybe shorten my pressure line an inch.
Some drivers get on the gas too hard after a bad pit and flame out. Then you got the guys that crash 78 times on the way down pit lane. I can go on....
I posted a thread much like this last year when we first started. The advice we've found to help the most is to rev the engine once before the tank is opened then let it idle only while the tank is open. Then a few revs before leaving the pits. It was said that when the lid is open there is no fuel pressure so if you rev while it's open the engine uses what little it can out of the line and you end up with a large air bubble from no fuel pressure. Then usually the first turn or lift point after the pit thedreaded flameout occurs. We've followed thisrule with much less trouble since. My son and many others shake the car too before putting it down. I don't know what this is supposed to do but many of the cool guys do it so we do too! LOL!
Good luck!
Good luck!
Good luck!
Good luck!
I used to have my driver rev when I picked the car up.
Then i'd refuel.
Then I hold the car out so he could rev, then I'd drop it.
Too hard to coordinate under pressure. Now I just grab it, fuel it, drop it.
What in the world could shaking the car do??? Is it after filling???
Then i'd refuel.
Then i'd refuel.
Then i'd refuel.
Never a day that I don't learn something on this site. I never knew not to rev while the lid was open
That's exactly what happened to me today. I came in, got fuel, and then the buggy died right after I went through the first turn. It was a turn where you jump up on top and then drive down the other side. When I came through it the engine leaned out and died right after. Oddly enough though my pit guy went and got the buggy, restarted it and got me back on the track without losing my second place position.
as for the fuel gun, we have a Pro Line model and on top of the fact that it leaks we used it for one stop and flamed in the pits! Needless to say no more trying that again til we can practice some with it!
Very common when pit stops are being stretched to the very limit. If the tank is dry enough and you wing on it, it will suck a nice big bubble of air into the fuel line. It basically runs the engine out of fuel even though the tank is full, because the line is dry. Solution is to either not push it as far or don't rev it while fueling. Without back pressure due to the lid being open for fueling, it gets much easier for the engine to suck in a big air bubble. There is nothing forcing the fuel into the engine. Usually when the tank is still pretty full(like 1/4 inch of fuel +) during a pit, it is much less common for a flame out due to this. There are plenty of other things like a bad tune or a dying plug, etc... that can cause a flame out after fueling. But the air bubble is pretty common as well.
Suspended
Good luck!
Good luck!
that and an improperly tuned engine = flameouts
