Old 07-18-2010, 09:42 PM   #16
JAMMINKRAZY's Avatar
Trader Rating: 17 (100%+)
Originally Posted by inferno13 View Post
very true!!!!! also alot of guys seem to want to give throttle when on lid waiting for marshall to flip back over, same thing happens here, stay off throttle and will stay running (if clunk is working right) as soon as you give a crap ton of throttle it is bound to suck air, less throttle the better
Well part of that comes from people trying to get the attention of a marshal by using their "nitro horn". Which I'll admit is necessary sometimes. Not that its good for your engine anyway. I'll say if a marshal is on their way to your car, and you're engine is tuned properly, you shouldn't need any throttle.
-Koby Kubrin-
Thanks to my Sponsors:
Serpent America | Team Novarossi | Desoto Racing | Race AKA | Ridgeway Bodies
JAMMINKRAZY is offline   Reply With Quote
Old 07-18-2010, 09:44 PM   #17
Originally Posted by tc5 man View Post
what about a dirty clogged filter i know that will cause a flameout .
You mean air filter or fuel filter? Air filter... you should be changing it well before that happens. Fuel filter... Throw it in the garbage where it belongs.
-Koby Kubrin-
Old 07-18-2010, 09:46 PM   #18
Suspended
Trader Rating: 202 (96%+)
normally if yor running fine before refuel a dirty airfilter-clunk is fine, its just the pressure when fuel tank is open that is effecting you, (sucking air for breif moment is all it takes)
inferno13 is offline   Reply With Quote
Old 07-18-2010, 09:48 PM   #19
Greenlee37's Avatar
Trader Rating: 32 (100%+)
something else to keep in mind..... if your pit guy fills your tank to the very top, when he snaps the lid back down, it can actually "push" fuel thru your line, and flood your carb, causing a flameout... This explains flameouts that occur before you leave pit lane, however, if your car dies by the time you reach the end of pit lane, or shortly thereafter, it is due to reving while the lid is open....
Mugen mbx6R
OS .21 XZB Speed w/ 2060
Mugen mbx6-T
OS .21 XZB Speed w/ 2050
AKA - KO Propo - Fioroni - Byrons - Hitec - UPGRADE
Greenlee37 is offline   Reply With Quote
Old 07-18-2010, 09:49 PM   #20
Suspended
this was a help question, not everybody knows that. just trying to give optional reasons this might happen
Old 07-18-2010, 09:50 PM   #21
tc5 man's Avatar
a air filter , which im learning now not to oil the outside of the outerfilter just the inside or have it dry.
not during my pit stop, did it flame out just all the sudden on the track im talking about.
yea i dont use fuel filters lol.
Old 07-18-2010, 09:53 PM   #22
Suspended
good point also, nitro is tricky, but when you get the hang of it, ITS ALL GOOD........well, i wont give my opion on electric.....LMAO!
Old 07-18-2010, 09:58 PM   #23
I just use losi or Lucky 7 filters oiled how they come and keep them fresh. Always change them before the main unless the one that is on the car looks basically new. If it is a long main I ALWAYS put a fresh one on.
I would think a filter would have to be pretty clogged to cause a random flame out. It will mess with your tune and rob power before it causes the engine to flame. I would look for another cause if it was out of nowhere that it flamed.
-Koby Kubrin-
Old 07-18-2010, 10:00 PM   #24
jbright33's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to jbright33
shaking is for creating alittle more oxygen in the fuel. its also a good way of tuning
JESSE BRIGHT
jbright33 is offline   Reply With Quote
Old 07-18-2010, 10:03 PM   #25
Racecrafter's Avatar
Trader Rating: 25 (96%+)
Originally Posted by mtbkym01 View Post
Can someone explain the principles of why an engine can flame-out after a refueling stop? I've heard it's to do with cold fuel reaching the carb.
The usual culprit is being too rich on the bottom end.
Jimmy Wright
www.trackstarrc.com ~ www.facebook.com/TrackStarRC ~ Home of the 2x's Stock Nationals Champion TS-Gold & TS-Black tire sauce, TS-1+ lubricants, TS-Precision bearings, XRG Xtreme Racing Grease, Scale Auto Engineering, ElevenTech, WRD2, Carbon 12, Stiff Products
Racecrafter is offline   Reply With Quote
Old 07-18-2010, 10:05 PM   #26
tc5 man's Avatar
i changed the outer filter after every round, there losi ones and i took some of the oil off it . well when i took my truck off the track when it flamed out the outfilter had gunk , all over it so my guess whould be it was clogged.
yea il look at my tuning, i think it was because my low end was kind of rich and my main needle needed to be leaned out a bit more. theres a small opening on the idle.
when i took it off the track, it was already cooling down it was about 215 so my guess it was running at 225 or cooleron the track but there was smoke coming out of the pipe .
Old 07-18-2010, 11:32 PM   #27
houston's Avatar
Trader Rating: 91 (100%+)
that causes a richer mixture
overly rich low speed needle = improper tune
TEAM FUSION X ENGINES / TEAM BYRON ORIGINALS / TEAM PROLINE RACING TIRES / TEAM SICK GRAPHICS /TEAM KYOSHO / things I support: COMP HEAT DEALER /TEAM LUNSFORD/ FUSIONX™ USA / TEAM KYOSHO / "H.E.S."™ / BYRON FUELS / RC-OMGUSA/KICWEBDESIGNZ/AKA TIRES/PROLINE RACING TIRES /RAYA RACING/BUKU POWER CLUTCH/M2CRACING/special thanks to STAV and JIM HOTTIGREENMOUNTAINGRILLS.COM
houston is offline   Reply With Quote
Old 07-18-2010, 11:59 PM   #28
tc5 man's Avatar
right i could tell too, when i hit the throttle it was sluggish all the sudden.
it was running fine intill, the outer air filter got cogged .
before the air filter, got dirty like that it wasnt that rich.
like i said i been told, to only oil the inside of the outerfilter.
the outside of the outer filter, was pretty dirty and the inside of the outerfilter was clean.
Old 07-19-2010, 12:44 AM   #29
mtbkym01's Avatar
Trader Rating: 26 (100%+)
Why then does it only flame out after refuelling, I've even seen it happen to pro's, and i'm thinking there tune is pretty spot on.
I'm liking the air bubble principle, certainly makes sense
~Kym Nuske~
RCHobbyzone.com.au / Model Motorsports International
Mugen Seiki 1/8, Reds, Neo+ Fuels
AE 1/10, Reds
"If it's old skool, it's kool"
mtbkym01 is offline   Reply With Quote
Old 07-19-2010, 02:16 AM   #30
mcsuperfreak's Avatar
Yeaaaaaaaaaaaaah, very good point for me too, I was reasoning just yesterday with my mate about this possible cause: when he next came in for refuiling and I was pitting, i tried to fill the tank gently to the top, and not filling the space where the lid thene comes in.
It may take some more time in pitlane (maybe 3-5 secs more) but will save 30+ seconds in case of flame out at the end of pit lane or at first turn.
IMO This point is important even if you have a fuel gun, because at each refueling not always the tank has the same amount left, and you can exceed the top of tank anyway.
mcsuperfreak is offline   Reply With Quote
Houstons Engine Service H.E.S. houston Offroad Nitro Engine Forum 8821 06-17-2017 12:29 PM
New Novarossi .21 offroad Plus 4 dsl Offroad Nitro Engine Forum 3759 09-01-2014 05:30 PM
Engine richens after refueling vti-chris Nitro Off-Road 19 09-07-2009 06:43 PM
Engine richens after refueling vti-chris Onroad Nitro Engine Zone 14 09-06-2009 10:03 PM
