Old 07-17-2010, 12:11 AM   #1
Lille-bror's Avatar
Default Reusing engine bearings
Gentlemen.
I friend of my, asked me a question, but I couldn't answer him 100% safe:
He needs a new rear bearing in his Orion engine (25,4 mm). He has an OS Vspec, that hasn't run very much (ruined piston). He asked me, if he could take the OS bearing out and put it into the Orion.
I suggested him to buy a new bearing (and a front bearing too). Personal I never heated up a bearing to 200 C, because I afraid it would destroy the bearing.
Can 200 C destroy a bearing? I'll assume the bearing never get that hot in a running engine.
Thanks in advance
www.xray-shop.dk www.northtq.com
Best regards Bjarne Petersson, Denmark
XRAY / FX Racing Engines / OS Speed / HPI / Byron / HUDY / Proline / Sanwa MT4s / Savx servos / Ultimate
I miss you Amy...
Lille-bror is offline   Reply With Quote
Old 07-17-2010, 12:27 AM   #2
Taking a bearing out by heating the engine to 200C will not ruin the bearing.
They are made of STEEL (or ceramic) and will hold up for a much higher temperature than that.
BUT, I would still try to talk him into buying two new bearings (front and rear) unless he has an extremely tight budget
If you are going to re-use the bearing make sure to not use any tools when getting it out and also make sure to clean it very very well.
Some denatured alcohol (do you have T-Rd in Denmark?) and then rince it with lots and lots of hot water in the sink, re-oil it and mount it.
Life's like a lemon and I want my money back!
Klimpen717 is offline   Reply With Quote
Old 07-17-2010, 03:53 AM   #3
j_blaze14's Avatar
Trader Rating: 34 (100%+)
it could work out fine but only if the orion is not his main motor. ive done it to mutt motors and they run fine for a couple gallons. also all the time and effort to get the 2 motors appart and re-assembled is a pain. you can get the ceramic main bearing for about $30 so i would just go new and run 1 slightly rich tank on the track to break it in. it will be a bit rough at first but will smooth out.
aGama A8 EVO - Werks B2 - Sidewinder
aGama A8E - TrackStar 150a, 2560kv, 3 and 4 cell
FlySky GT3B, Turnigy HV servos, SKY Lipos
AKA, Proline, Hotbodies Rubber
Elite Performance - HORRC.com
j_blaze14 is offline   Reply With Quote
Old 07-17-2010, 06:46 PM   #4
Paulus's Avatar
Get some new bearings.
If the OS v-spec got a ruinend piston and sleeve then the debris of that would have gone trew the bearing also.
I wouldend take that change, get some TKO ceramics and you will be good to go.
Teamdriver for: MugenSeiki, MBX7, MBX6-TR, OSspeed engines, Power-Safe-Racing fuel, JVDrc clutches, Sanwa/ Savox electronics.
All the way from the Netherlands :)
Paulus is offline   Reply With Quote
Old 07-17-2010, 08:30 PM   #5
Lille-bror's Avatar
Hi.
Thanks guys
He did buy new bearings and everything is fine.
Back to heated bearing: I was afraid of the sealing on the front bearing and the cage (ball holder???) on the rear, because they are normally made of non-steel material.
Swede: Yep, we got that type of alcohol here in DK. I normally use petroleum, because that takes away the dirt but leaves the fine oil-film on the material.
I miss you Amy...
Old 07-18-2010, 01:11 AM   #6
Dane: Petroleum is OK but I'd rather prefer a pure cleaning with no residue and then add what I want for that particular item. If its a bearing I add bearing lube or grease, if it's plastic I don't want anything left on there and you can drink that stuff too..... NOT! (you got Tuborg, right? )
Old 07-18-2010, 09:13 AM   #7
Lille-bror's Avatar
Thanks Swede
Yep, we got Tuborg beer. Sadly, you'll get drunk after only one Tuborg!... You have to drink 10 Carlsberg to get rid of the Tuborg taste!!!
Cheers
I miss you Amy...
Old 07-18-2010, 09:28 AM   #8
Frank L's Avatar
Trader Rating: 148 (100%+)
Use a being puller it just makes life so much easier. The grp kit was king and now i see hudy has one out too. It's $$$ well spent.
Old 07-18-2010, 10:57 AM   #9
What do you mean? What is a "being puller"?
STS engines sparksy Onroad Nitro Engine Zone 2774 02-03-2013 06:05 AM
First Time engine tear down questions. H9_nutter Nitro Off-Road 13 11-25-2009 11:34 AM
Help! - My Teamlosi LST RC truck won't start, maybe engine broken? helgso Nitro Off-Road 61 05-26-2009 05:52 AM
cleaning bearings pro4racer Electric On-Road 8 07-17-2005 09:45 AM
