Old 07-14-2010, 02:53 PM   #1
xray2050's Avatar
Trader Rating: 14 (100%+)
Default Replacing Engine Bearings
Hey Guys
I need to change the front and rear bearings in my Axe Rossi motor. They feel like they are getting sloppy… This is something I haven’t done before but it really doesn’t look that complicated. Can anyone give me some tips or pointers on how this should be done correctly or “the easy way”
Do I need a press or anything else special?
This motor is for my 1/8 buggy.
Pete Elphinstone
RC America, HUDY, XRAY, JACO, Performance Hobbies, WERKS RACING, www.speedzoneusa.com, Sweep Racing USA
xray2050 is offline   Reply With Quote
Old 07-14-2010, 03:11 PM   #2
newuserlosi8t's Avatar
Trader Rating: 65 (97%+)
strip the motor bare stick it in the oven or heat gun get it to 240 and lightly smack the rear end on something like wood and should pop right out use a wood dowl to push the frnt one out u tube has a good video best way just get a bearing puller u will need it again
zo1b team option buggy
mg66 go 2072 a main fuels savox servos
TEAM DRIVER FOR----ANSWERRC-USA--- PREMIEREHOBBIES--answerrcusa.com-http://premierehobbies.com ***Contact me for pricing and information on Argus, Hyperion, Max Amps, Durango and Savox***
newuserlosi8t is offline   Reply With Quote
Old 07-14-2010, 03:20 PM   #3
Stanton's Avatar
Put the engine in an oven at 250deg for 15 min. Use an ove glove to handle and the bearings should fall out by just tapping the block on a hard surface. You can use the crank to help align the rear bearing once it’s loose in the case. It's a little tedious getting it lined up and out of the case
If you’re quick you can put the new bearings in while the case is still hot. It's best to have a bearing alignment tool to get the bearing aligned perfectly. You can tap on the bearings a little to get them aligned, but sometimes it's pretty hard to get them perfect. If you’re replacing with ceramics, don't tap on them or you will chip the balls. You need an alignment tool for ceramics that presses on the outer races only.
Horizon Hobby/Spektrum/Byrons/TLR/Houstons Engine Service
Stanton is offline   Reply With Quote
Old 07-14-2010, 03:35 PM   #4
xray2050's Avatar
I need this engine fixed now so I have to get the bearings from my LHS. The only bearings he had in stock was a steel front bearing and a ceramic rear. I will be careful not to tap the ceramic.
Pete Elphinstone
Old 07-14-2010, 03:38 PM   #5
Marcus Falconie's Avatar
put the bearings in the freezer they go back in alot easier just put the rear bearing on the crank and push it in. If the block is still hot it should be no prob.
Marcus Falconieri
2011 Xray 808
Torco Racing Fuels
KBRL Nitro Series
www.youtube.com/gsadvanced
Marcus Falconie is offline   Reply With Quote
Old 07-14-2010, 03:38 PM   #6
http://www.youtube.com/watch?v=WhpwsjYoxM0
/end thread
bacchus is offline   Reply With Quote
Old 07-15-2010, 03:38 AM   #7
JayRC66's Avatar
Default LRP .28 spec 3
I have to change my rear bearing on my motor. Will probably purchase a bearing puller kit.
Jovanny S.
Losi, Serpent, Schumacher, Ofna.... yea I got a little bit everything.
JayRC66 is offline   Reply With Quote
Old 07-15-2010, 08:36 AM   #8
Stanton's Avatar
That is the best way, but bearing pullers are expensive and not absolutely necessary. It's more important to get a bearing alignment tool to make sure they are perfectly aligned.
Old 07-15-2010, 08:49 AM   #9
Stanton's Avatar
Originally Posted by bacchus View Post
I like the video, but what they don't cover is cleaning the block before putting the new bearings in and you can't align the bearings with the crankshaft because it only touches the inner races. The NR alignment tool is awesome and it aligns the outer races. I use it on brand new engines and not always, but sometimes will free up a brand new engine. They are the shizit!
Old 07-15-2010, 09:01 AM   #10
segui305's Avatar
Send a message via Yahoo to segui305
so your saying putting the bearing into the crankshaft is NOT the best way to line up your bearing, and why????
Team Losi 8ight 2.0 buggy- Proline- j concept- Futaba 3pks Spektrum module- hi-tec servos- jr9811-Dynamite Mach .21-OS VZB V-SPEC .21-Team Str8 killaz
segui305 is offline   Reply With Quote
Old 07-15-2010, 09:15 AM   #11
Stanton's Avatar
Because the crank is trying to use the inner races to push the balls against the outer races. Think about it. All those little balls are aligning the outer races. Like I said, its not the best way. The best and correct way is to use an alignment tool that alignes the outer races. Once you use one, you will agree.
Old 07-15-2010, 09:31 AM   #12
segui305's Avatar
what does that tool look like, im trying to search for it but i cant find it!
Old 07-15-2010, 09:39 AM   #13
Stanton's Avatar
http://www.novarossiusa.com/index.php?cPath=54_55
Old 07-15-2010, 06:03 PM   #14
Hey Guys
here are some tips from RB:
http://www.rbproducts.com/mainEn.php...ncept%20engine
Powered by: MASTERCARD and VISA
If you're in control, you're not driving it fast enough!
XRAY / NOVAROSSI / SANWA / AKA TIRES / BYRON FUEL
ganymede is offline   Reply With Quote
Replacing engine bearings bacchus Nitro Off-Road 15 06-01-2010 01:27 PM
