Old 07-14-2010, 09:46 AM   #1
Default lubricants
as for my first post. has any or heard or have any data on using automotive gear lube in the diffs?
ive got a ton of royal purple diff 80-90 wt sitting in my garage
im running a d8t
killerkoolaid is offline   Reply With Quote
Old 07-14-2010, 09:48 AM   #2
Integra's Avatar
$ for $ Run the stuff we know works.
Old 07-14-2010, 04:33 PM   #3
jammin32j's Avatar
I think the cen uses gear oil in the rear diff but other than that I have never heard of any one using it. Diff fluid is cheap and a bottle goes a long way.
VP Pro, Agama
Hitec-7955's, 3Pk----AKA Racing Tires
Absolutehobbyz.com____Dirtrc.com
O'Donnell, D.I.R.T. R/C ultimate Tire Gluer
Jeremy Davis
jammin32j is offline   Reply With Quote
Old 07-14-2010, 04:41 PM   #4
ScottyM's Avatar
Trader Rating: 27 (100%+)
Agreed, but the Idea is a nice one.. A quart of 75w90 could last you for years.. Oh Wait if you don't change tracks often then a bottle of diff fluid can last that long too..
Scott Musgrave
ScottyM is offline   Reply With Quote
Old 07-17-2010, 12:24 PM   #5
i think im going to start doing some testing with viscosity...lucas oil stabalizer is super close to 20k
Old 07-17-2010, 12:52 PM   #6
I was rebuilding my smart diffs every race, with the losi recommended grease, started using Synthetic gear lube 75w90 on my Losi 2.0 smart diffs and they become more consistent, ran cooler and would last for 4 to 5 races, down size is that stuff stinks and your hands will too for a few days. I am now using it on the Fioroni tractive diff for the MP9 and just as happy.
Rui Almeida
Hamilton, Ontario
CANADA
I am not sponsored, these are the products I chose to support.
Serpent SRX8, Sanwa M11s, Sanwa SRX-BX servos, Picco 5TB
RAlmeida is offline   Reply With Quote
Old 07-17-2010, 01:04 PM   #7
Remember, using silicone oil is due to it not changing viscosity in a meaningful way due to temperature changes. So you get consistent performance all day. So a oil that is temperature stable, and of the same viscosity, should be golden.
B!
Mr B is offline   Reply With Quote
Old 07-17-2010, 01:21 PM   #8
B!
i totally agree. i would only test straight weight oils. probably going with syth oils.
Old 07-17-2010, 01:44 PM   #9
Send a message via AIM to A-Ko
I have been very happy with this stuff. Works perfect in the diffs.
http://airsoft-club.com/shop/interna...ease-lubricant
Jeffrey
teamgravityrc.com - motivrc.com
USVTA National Points Member #101
A-Ko is offline   Reply With Quote
Old 07-17-2010, 02:15 PM   #10
Grease only works when your looking to reproduce the response of a very thin oil. It's not going to cut it when you want something thicker, and want a diff that actually locks up, and forces the same rotation speeds on the outgoing shafts. For my "base" setup, it could work in the rear, only. I run 7/10/1K Front/Center/Rear on my buggy.
B!
WTS : NEW & 2NDHAND (SERVO FUTABA, ENGINE, SHOCK ABSOBER, LUBRICANTS & CHEMICALS) zannuar Malaysian Forsale-Trade 8 01-16-2010 04:42 AM
Bearing lubricants scarymonster Electric On-Road 14 01-28-2008 07:13 AM
What lubricants shall I buy? halayli Electric On-Road 50 08-17-2006 03:32 PM
Gear Lubricants versa Electric On-Road 24 01-09-2004 11:32 PM
