Losi 8ight 2.0 Buggy Issue
I just bought a used 8ight 2.0 buggy from here last week and just put in a couple ace servos last night. For steering i'm using a 1015 and 1313 for throttle. Anyhow when i turn the wheels to the right at the very end it makes a slapping sounds. Sounds like 2 pieces of plastic hitting each other. I messed with it for about 3 hours and could not for the life of me figure out what was making that noise. I have the EPA set for both left and right steering correctly on my radio but the problem persists. It doesn't seem to impede the wheels from rotating when in full lock to the right, so i don't know what the deal is.
I'm not sure if its a big deal or not, so i just wanted to ask if anyone else might know what the problem is or if its a problem at all. It'll be a couple days before i drop the engine into it, so i have abit of time to figure it out. Any assistance would be greatly appreciated.
On a side note the buggy came with an extra set of front axle carriers, although the axels carriers on them seem to be just fine. It also came with a left rear a arm (guessing the right a arm broke at some point in time and he just had the left one left over from the package). But i figured i'd post that as well.
Sounds like the the spindle stop is slapping against the hub carrier when it goes to full lock.. Try adjusting the trim away so that is doesn't bottom out when you turn all the way..Then try it to see if it helps..
