Old 07-13-2010, 04:09 AM   #1
dj_sparky's Avatar
Send a message via MSN to dj_sparky
Default Large rear wheels and small front wheels?
How will such a setup effect the differentials? Reason I am asking is because I ended up remaking a DBX with large rear wheels and small front wheels.
dj_sparky is offline   Reply With Quote
Old 07-14-2010, 01:35 AM   #2
If you have a center diff that would be effected.
It would constantly work to even out the load on the front and rear axle rotation.
If you DON'T have a center diff you won't be able to drive at all.
Life's like a lemon and I want my money back!
Klimpen717 is offline   Reply With Quote
Old 07-14-2010, 12:47 PM   #3
toobad4u's Avatar
Trader Rating: 93 (100%+)
I know with the Ofna Sprint, it comes with different size front and rear wheels. The people that tried it out on the local oval said it pushed real bad if the turns if you were on the throttle. It wanted to go straight when the throttle was applied. aybe if you used a real thin center fluid, it might work okay.
Stephen
Mihabi RC Your Hometown Hobby Shop.
(850) 914-2815
toobad4u is offline   Reply With Quote
Old 07-14-2010, 12:49 PM   #4
Trader Rating: 12 (93%+)
You will pull up the front wheels a lot!
rcdude236 is offline   Reply With Quote
Old 07-14-2010, 01:00 PM   #5
captain america's Avatar
At the very least, your front tires will wear faster, especially if you use high-viscosity oil in the center. The latter will also be highly solicited by that setup.
captain america is offline   Reply With Quote
Old 07-15-2010, 12:27 AM   #6
Stephen
If I understand you correct you're talking about a car that came stock with different sizes? If that is the case they also have different gearing in the front diff vs the rear diff OR no diff fluid in the center diff (a bad thing).
Think of large modern 4x4 tractors, they have pretty big difference in tire size.
Old 07-16-2010, 01:45 PM   #7
toobad4u's Avatar
The gears inside the cases are the same front to rear. The center is a regular type differential from Ofna so it just has a little grease in it. Where we race, everyone has to use foams only, so it doesn't really matter since they are the same front and rear. It probably only comes with the different sizes to increase the realism.
Stephen
(850) 914-2815
Old 07-16-2010, 02:42 PM   #8
ScottyM's Avatar
Trader Rating: 27 (100%+)
I'm wondering if the OP means Wider or taller (ie bigger Diameter)?
Wider won't make much difference, but taller can cause problems, if not regeared to compensate.
Scott Musgrave
ScottyM is offline   Reply With Quote
Old 07-16-2010, 03:56 PM   #9
dj_sparky's Avatar
Thank you all for your help.
I meant bigger all over. Taller, wider. It will indeed struggle a bit more, but I was hoping it would work atleast.
I guess I'll just remove the front drive shafts and make it rear wheel drive only.
Does anyone happen to know of a stronger gear set/differential that will fit the DBX?
Associated Factory Team TC5, Brushless, LiPo, Li-ion Nanophosphate, Tips and Tricks John Stranahan Electric On-Road 839 11-01-2011 03:31 PM
Pantoura, 1/10 Pan Car, 2S LiPo, Brushless, Tips and Tricks. John Stranahan Electric On-Road 2178 12-01-2010 10:26 AM
Tamiya 58431 F104 Pro with Hop-ups and Spares Doog R/C Items: For Sale/Trade 7 02-16-2010 10:28 AM
