Old 07-13-2010, 12:10 AM   #1
lewis666's Avatar
Send a message via MSN to lewis666
Default brake pad springs?
hi there,
i am looking for some brake pad springs for my losi 8ight. i have found these:
http://www.m-k-racing.com/product_in...61b3f5d898d3d5
but has anyone tried them? i was looking for brake pad springs that come in different rates, has anyone got a link?
many thanks
lewis
Durango DEX410R, BCE Losi 8ight 1.5 (radical 621t), Durango DESC410R on the way!
radical engines- www.gotnitroonline.com
Got nitro team driver
lewis666 is offline   Reply With Quote
Old 07-13-2010, 01:23 AM   #2
mrbusta's Avatar
Trader Rating: 20 (100%+)
Send a message via MSN to mrbusta Send a message via Skype™ to mrbusta
Originally Posted by lewis666 View Post
hi there,
many thanks
lewis
u could always use the springs out of the clicker pens just as easy and cheap
SHAYNE/MONSTER ENERGY/BETA TYRES Australia
Thanks to www.wprcracing.com/P.N.D Paint works
81/MUGEN Mafia
RIP BUSTA BB ANGEL
mrbusta is offline   Reply With Quote
Old 07-13-2010, 05:59 AM   #3
or you can also use the Associated 12L series of front 12th scale springs... they have 3 or four different rates to choose from
Leon McIntosh
PRO-LINE--XRAY--RCAmerica--FX Engines--NitroPro Fuel--Kustom R/C Graphics--Schelle Racing
******* DialedSetups.com ****** Check it out!!!!!
punkracer24 is offline   Reply With Quote
Old 07-13-2010, 07:37 AM   #4
lewis666's Avatar
or could you use any 12th scale springs? but i looked on the associated website and found this:
http://67.199.85.166/main/maincatego...&nav=on1.12nav
there are 6 different rates, but which do you recommend? that is if i can find them!!
many thanks
lewis
Old 07-13-2010, 08:01 AM   #5
off road god's Avatar
Ok. Now you have really lost me....different spring rates? Is your servo to weak to push the pad with your springs in place? I've ran them for 3 yrs now and with great success...they keep the pads from riding on the rotor. Have they become a tuning tool also? I thought the servo applied the needed pressure and the adjustments were for the amount of pressure....and Dynamite makes a good spring.
WERKS RACING...PRO1RC...HEX CREW...BATTLEFIELD R/C...LOSI 2.0...JP PIPES...AKA,PROLINE TIRES...SPEKTRUM DX3R...JR SERVOS... PAUL CONWAY,TECHNICAL ADVISOR.
SAKURA ZERO S...NOVAK ELECTRONICS...MI SERVO...HPI PRODUCTS...FUTABA
off road god is offline   Reply With Quote
Old 07-13-2010, 08:22 AM   #6
lewis666's Avatar
hi there,
mike stanton recommended that i get some springs to go between the pads. but he also recommended that i get rid of the fuel tubing on the brake linkage and get some springs.
i currently do not have any springs on the pads or the linkage what so ever. and mike recommended that i have a stiffer/shorter spring on the linkage for the back brake so the back end slides round.
i am wanting the same spring rate between the pad but a stiffer/shorter spring on the rear brake linkage and a longer/softer spring for the front brake linkage.
do you understand?
many thanks
lewis
Old 07-13-2010, 08:33 AM   #7
lewis666's Avatar
i have found the right springs for the brake pads these:
http://www.answer-rc.com/product.php...012pk&catid=22
but i need some springs for the linkage, they need to be stiffer then the ones on the brake pads?
any suggestions?
many thanks
lewis
Old 07-13-2010, 08:44 AM   #8
RCmayor's Avatar
Send a message via Yahoo to RCmayor
any suggestions?
many thanks
lewis
Fuel tubing works good.
RCmayor is offline   Reply With Quote
Old 07-13-2010, 09:48 AM   #9
hi there,
do you understand?
many thanks
lewis
Ohhh...ok. I use Dynamite springs between the pads. I use a spring on my throttle linkage and fuel tubing on both break linkages...you can cut it suit your need and use the adjusters to fine tune your brakes.
Old 07-13-2010, 11:14 AM   #10
rcgeezer's Avatar
Those AnswerRC brake springs are awesome, you'll really like them!!
**Team Terribles Northern CA Regional Rep.**
Cold Fusion R/C Products Team Driver
Answer-RC USA / Team Sweep Racing USA
Team RcRenew...visit us at rcrenew.com!
Triton RC Alpha Plus Engines
rcgeezer is offline   Reply With Quote
Old 07-13-2010, 11:14 PM   #11
lewis666's Avatar
i have heard that they rub on the losi 8ight brake discs? has anyone tried answer rc springs on a losi 8ight?
many thanks
lewis
Old 07-13-2010, 11:15 PM   #12
lewis666's Avatar
hi there,
i am only trying what mike stanton recommended. but if a got a spring off a throttle linkage and cut to size would that work?
many thanks
lewis
Old 07-13-2010, 11:20 PM   #13
Haven't tried the Answer RC springs. I started with a set from Trinity. They worked good but, not very long. My LHS had me try the Dynamite. Less expensive,fir great and wear forever. I'm a happy camper...
Old 07-13-2011, 09:49 PM   #14
TX_Punisher's Avatar
Bringing back an old thread.
Has anyone else tried this? I was thinking of implementing something like this but am wondering how long of a spring to place in between the pads? 5mm?
XRAY XB9 & XT8 ☆ Airtronics M11X ☆ Novarossi Powered☆ Werks Fuels ☆ Hitec
TX_Punisher is offline   Reply With Quote
Old 07-13-2011, 10:00 PM   #15
Trugsta's Avatar
Send a message via MSN to Trugsta
Its overkill and if the kit really needed them then they would have been provided with the kit.
It dosent make sence to me If you have your breaks setup correctly then theres no need for these..
Proud Member of S.C.O.R.C.
Losi 8T2- Novarossi P5/Novarossi and GRP pipes.
spektrum DX3S. SAVOX servos. "Race till it MHZ"
A huge thanks to.
www.motorsaver.com (the absolute best filters and savers on the plannet).
Trugsta is offline   Reply With Quote
Mugen MBX6T Mugen9112 Nitro Off-Road 8494 04-12-2017 12:03 PM
Odonnell Buggy!!! Brad S. Nitro Off-Road 9373 06-03-2016 10:45 AM
Avid VS Carbon fiber brake disks vti-chris Nitro Off-Road 8 11-05-2008 12:14 PM
MBX5, MBX5R, FIBER BRAKE ROTORS K.Copeland R/C Items: For Sale/Trade 18 03-09-2008 09:17 AM
