Old 07-11-2010, 07:25 PM   #1
tc5 man's Avatar
Default air filters
ok heres my question do you guys, run your outerfilters dry when the track is dusty and dry ? because when i was, running at my track my filter had guck all over it and my engine, flamed out all the sudden and my engine started to run richer .
so do you think i should just run, my outfilter dry because i think thats what is causeing my flame out and clogging up my engine.
Old 07-11-2010, 07:33 PM   #2
trevor15308's Avatar
Send a message via Yahoo to trevor15308
i put oil on both my filters,it doesnt clog my motor
AGAMA RACING-TKO BEARINGS-AIRTRONICS-SIDEWINDER-WERKS-PROLINE-VP PRO USA-RCrenew.com
trevor15308 is offline   Reply With Quote
Old 07-11-2010, 07:36 PM   #3
tc5 man's Avatar
well im using the pre oiled losi filters, and i did wipe some oil off of them and it still got oily gunk on the, filter i know thats has to clog the air up.
it was fine when the track was moist .
Old 07-11-2010, 07:37 PM   #4
Quad Racer 34's Avatar
Trader Rating: 4 (83%+)
same here.. A little trick I learned from someone on here is oil the inner filter and then oil the inside of the outer filter. So the dust wont stick to it and the little bit that does get through it wont make its way through. I've been doing it ever since.
Dylan Gerard
Serpent - Desoto Racing - Picco - AKA - Hitec - RC Addictions Products - Tekin - VRP - Avid RC - SMC - MIP - SkipGear - The Ohio RC Factory
Quad Racer 34 is offline   Reply With Quote
Old 07-11-2010, 07:40 PM   #5
tc5 man's Avatar
Originally Posted by Quad Racer 34 View Post
same here.. A little trick I learned from someone on here is oil the inner filter and then oil the inside of the outer filter. So the dust will brush off easy but wont go through the filter. I've been doing it ever since.
oh ok i get it. but is it ok to run the outer filter dry on a dry track ?
i do run a inner filter too or, do you have to have the outer filter oiled ?
Old 07-11-2010, 07:41 PM   #6
Cory Kerber's Avatar
I tried that last race. The dirt no longer "cakes" on the outside of the filter. I will continue to do this.
Losi 8ight-Novarossi N21R-Hitec Servos-AKA-M11 Spektrum
*TEAM TERRIBLES*
Cory Kerber is offline   Reply With Quote
Old 07-11-2010, 07:43 PM   #7
Default re
you can run the outer filter dry,ihave for along time,but like he said turn the outer filter inside ot and oil it a little then turn i right side out and install it I am gonna try this
toofless is offline   Reply With Quote
air filters mixedguy Nitro Off-Road 41 08-06-2008 01:59 AM
Cleaning Air Filters? busta774 Nitro Off-Road 57 02-25-2008 07:51 AM
To save or not to save (Air filters) Rosco Nitro Off-Road 21 06-20-2007 10:49 PM
Are all air filters created equal? rmdhawaii Nitro On-Road 26 01-13-2007 07:20 PM
