Old 07-13-2010, 10:33 AM   #31
cdc
Originally Posted by RCBOY 1 View Post
ok yeah but arent you going to put a rb k10 on that rc8b you have
yeah once get enough money for a RB k10
Kyosho MP9 TKI4 - OS SPEED - KO RSx Servos - Futaba 4PX
cdc is offline   Reply With Quote
Old 07-13-2010, 12:41 PM   #32
Originally Posted by Klimpen717 View Post
What is your thought on this one? Are the engine harder to tune with a ceramic bearing? If not using a ceramic, what do I use instead? Anyone??
My experience with ceramic front bearing (ceramic main bearing is okay) is that they leak when they are cold. There are several threads in here on this topic, and I can read that it is a common problem.
Sure, don't tune it while it is cold, but some of the SH engines (with ceramic front bearing - not standard) I am responsible for, even leak when warm. That makes it a bitch tuning!
Niklas Hansen
Team TCHobby / Team Upgrade-RC
Tamiya TRF417 / Speed Passion GT2.0 / Speed Passion V3 motors.
Nilks is offline   Reply With Quote
Old 07-13-2010, 12:49 PM   #33
JAMMINKRAZY's Avatar
Trader Rating: 17 (100%+)
I use quality TKO double sealed ceramic front engine bearings. No problems here. I don't see how a bearing being ceramic would make it leak any easier than a steel bearing. The rubber seal(s) are what seals them up, and they have nothing to do with the bearing being ceramic or steel. I would say, maybe if you are using cheap ceramic bearings that have crappy seals, it would seem like the ceramic bearing leaks. But in actuality, it is just a poorly made bearing seal. If you use good ceramic bearings with good seals, there are ZERO issues.
-Koby Kubrin-
Thanks to my Sponsors:
Serpent America | Team Novarossi | Desoto Racing | Race AKA | Ridgeway Bodies
JAMMINKRAZY is offline   Reply With Quote
Old 07-13-2010, 01:05 PM   #34
I have experienced problems with 4 engines now. 2 RB's (with RB ceramic bearing) and 2 SH's.
This thread contains some thoughts on it too.
Ceramic vrs Stock bearings???
Niklas Hansen
Old 07-13-2010, 01:25 PM   #35
RCBOY 1's Avatar
once you do that that thing will be even faster but did you ever get that new wheel for your bumpbox?
RCBOY 1 is offline   Reply With Quote
Old 07-13-2010, 01:43 PM   #36
segui305's Avatar
Send a message via Yahoo to segui305
thanxs for all the replies. ill figure everything out little by little, i just gotta play with my motor and figure what my motor is telling me. its looking like the o.s is going to be a easier motor to tune. i also heard that the o.s has the best carburetor in the market, ive also heard that the seem to loose there compression faster than any motor.
Team Losi 8ight 2.0 buggy- Proline- j concept- Futaba 3pks Spektrum module- hi-tec servos- jr9811-Dynamite Mach .21-OS VZB V-SPEC .21-Team Str8 killaz
segui305 is offline   Reply With Quote
Old 07-13-2010, 01:54 PM   #37
Yeah, the compression isn't great, but they will still run great. That is just how OS engines are.
Niklas Hansen
Old 07-13-2010, 02:04 PM   #38
claymonkey's Avatar
Originally Posted by axle View Post
+1
+1
The golden rule rulez. The world is nuts, let's go racin!!
Mugen MBX6R, MBX6T
Associated B4.1FT, SC10FT
claymonkey is offline   Reply With Quote
Old 07-13-2010, 02:08 PM   #39
claymonkey's Avatar
Originally Posted by Chris Reilly View Post
Neither is hard to tune. OS is no easier. I have both. understanding what it's telling you is the key.
OOPS I meant to quote this one.
+1
Mugen MBX6R, MBX6T
Old 07-13-2010, 03:17 PM   #40
segui305's Avatar
+1
+1
Old 07-13-2010, 03:18 PM   #41
segui305's Avatar
+2
Old 07-13-2010, 03:24 PM   #42
golferdude1971's Avatar
Trader Rating: 18 (100%+)
Originally Posted by RAlmeida View Post
OS engines.
+1000
golferdude1971 is offline   Reply With Quote
Old 07-13-2010, 07:57 PM   #43
claymonkey's Avatar
I am not a OS guy for R/C cars, but have tuned a few, and they are not finicky as some other brands out there, but then again there really is no engine to finicky for me to tune,"not tootin my horn" It is just that I have been tuning nitro engines since I was 8 yrs old, " grew up flying with my dad" I have tuned sport, some 4 cycle "different animal altogether" and racing, pylon engines for years. Case in point, if anybody knows K&B engines #4011 in particular was a pain to tune no matter what carb you used. I could make that joker scream! if you gave me a little time to learn "that " engine as they all ran a little different. I have tuned a few for guys that were racing for years and could not get the thing to run just right. It is kinda like a piano tuner, or tuning a guitar, it takes an "ear" for it. FORGET temps, take your time and let the adjustment settle in, listen to it, fell it, be patient, it will talk to you just listen. There is NO sweeter sound then a perfectly tuned nitro engine,"to me" my wife and neighbors do not feel the same! lol. Car engines take a little more patience as the load on the engine varies alot more, BUT the principal is the same. The sound should be a high pitch, smooth, consistent tone at all ranges of the rpm. Sorry this was so long. Happy motorin guys. The engines today are waaayyyy easier to tune then they were 25+ years ago.
Mugen MBX6R, MBX6T
Old 07-13-2010, 08:06 PM   #44
claymonkey's Avatar
a few things to ask to get the learning of the engine out of the way if you are new to that engine. First ask the guys running them the heat range "plug" head shims, and pipe that engine likes for the type of running you do. Saves alot of time and money. Airplane race engines, we tune the pipe length to the engine we have and what prop we are using for that specific plane we are flying, ie pylon the prop is smaller dia. heavy pitch "rpm's baby!" pattern prop, big dia. less pitch, toke some playing to get it just right. But when it is on, IT"S sooo sweet!
Mugen MBX6R, MBX6T
Old 07-13-2010, 08:11 PM   #45
I run ceramics front and rear in all of my engines. Not one single little problem. I'm talking MANY engines. All TKO's with double seals. So I'm not sure about other crappier ceramic bearings, but the TKO's don't leak any more than a standard steel bearing does, in fact probably less.
-Koby Kubrin-
MAXY'S FUEL SOLOARTIST 702 Nitro On-Road 999 11-09-2010 05:53 AM
What is the best way to learn how to tune a nitro truck? Nitro F150 Nitro Off-Road 10 12-02-2009 01:03 PM
What's your impression of this Tmaxx? DSMStyle Monster Trucks 17 10-01-2003 07:06 PM
