Old 07-20-2010, 09:22 AM   #16
deeje929's Avatar
What kind on plug are you guys running with it.
Team orion, Kyosho, OS
deeje929 is offline   Reply With Quote
Old 07-20-2010, 11:07 AM   #17
dandrat's Avatar
odonnell 97t, runs great
dandrat is offline   Reply With Quote
Old 07-20-2010, 03:09 PM   #18
FLHX1550's Avatar
+1 Been running the 97t and 77t with no issues at all
FLHX1550 is offline   Reply With Quote
Old 07-20-2010, 05:28 PM   #19
Kalgard Racing's Avatar
I run the Orions with good success. I tried some OS's and blew them quick....not sure why? I haven't tried the OD, but I will.
Kalgard Racing is offline   Reply With Quote
Old 07-21-2010, 04:29 AM   #20
I've been running OS P4's with pretty good results thus far.
So far, I'm not quite getting the run time I need but the motor has only got 2 litres through it now and is obviously still pretty tight.
However very punchy off the bottom and to mid, but does die off a bit for high rpm, which could also be due to still being tight.
I will be trying different pipes etc and will keep you guys informed on my findings.
Kev Lewis,
I'd like to thank my personal Sponsors :-AKA Tyres Australia, Ryper Hobbies and Just Hobbies
The Gear :- Associated RC8 B3 powered by OS Engines
Soapy is offline   Reply With Quote
Old 07-21-2010, 06:03 AM   #21
deeje929's Avatar
I was just asking because I run the Orion #6 plugs. And I never had a issue either. Other than running it for months and on main dayI forgot to change it out. 2 months worth of running. Going to try a Orion 7 to see what kind of mileage a get
Old 07-26-2010, 10:03 PM   #22
floss's Avatar
Trader Rating: 32 (100%+)
Kev , I take it you have started with the pipe that comes in the combo, 2057 , looking at your Sig you run a Mbx6 , what header are you using is it the combo header or are you using the Ninja tight header long or short ....
REDS RACING ENGINES
Model Motorsports
floss is offline   Reply With Quote
Old 07-26-2010, 10:22 PM   #23
Hi Paul,
In the truggy I ran the Orion Pipe that came with it but with a shorter mannifold to get more top end. The problem with Orion/sirio pipes compared to os/ninja pipes is they have 4 spring retainers compared to os's 3, which basically means you can't use orion pipe combo on the buggy because of the wide header and you can't put the narrow header on orion pipe. I ended up just using ninja pipe with narrow header, I think it's called C or J Type. Power was still good but I will make some little mods to get the orion pipe on there to see performance difference.
I hope that makes some sense..lol
Kev Lewis,
Old 07-30-2010, 12:35 AM   #24
floss's Avatar
I see ya point Kev , I have just sold my Maxpower engine and the header issue is the only thing stopping me from going with the Orion at the moment , I have previously put a Sirio pipe on a different header for a customer with no probs , just not sure I want to do that on my own buggy ...
REDS RACING ENGINES
Model Motorsports
Novarossi engines thread EVOLUTION Onroad Nitro Engine Zone 5360 08-14-2017 11:48 PM
Sirio engines thread EVOLUTION Offroad Nitro Engine Forum 2824 04-29-2014 10:58 AM
