Old 07-09-2010, 04:41 PM   #1
mike881's Avatar
Default did I mount these right?
I ordered jconcepts barcodes for my 1/8 and if you look at the picture, the tire doesnt have the same tread the whole way around. When looking at the photo, the bottom side is mounted on the inside of the rim. The outside of the rim( top of the picture), where there is less tread is on the outside of my tire. Does that seem right?
mike881 is offline   Reply With Quote
Old 07-09-2010, 05:39 PM   #2
pantera nitro's Avatar
from what ive seen (i've never owned a pair) the outside edge of the tire is the side with the > where your finger tips are and the side with the U is the inside edge!
MP9-TKI2/O.S. 21XZ-B V-Spec Speed
RC8T-CE/MG66X
RC8B-e/Hobby Wing
RC King Hobbies - onlinerc.com.au - Pro-Spec Race Bearings
pantera nitro is offline   Reply With Quote
Old 07-10-2010, 02:16 AM   #3
ScottyM's Avatar
Trader Rating: 27 (100%+)
I don't have any nor have I seen any mounted. I would assume they are made the way they are to give a tuning option. IE no wrong way to mount them.. One will give more or less side grip depending on track conditions and set up..
Scott Musgrave
ScottyM is offline   Reply With Quote
Old 07-10-2010, 02:25 AM   #4
jbright33's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to jbright33
beleive thats right they will set in more when you run them to.
JESSE BRIGHT
jbright33 is offline   Reply With Quote
2nd cracked case.. engine mount problem. any suggestions? builtb16a Nitro Off-Road 39 08-15-2009 12:44 AM
