Old 07-09-2010, 11:06 AM   #1
koopesv's Avatar
Trader Rating: 18 (95%+)
Default Picco P3 .28 problems
Ok I have a Picco In my lst 2, the problem is when I went to start seemed like i needed a new glow plug or charge the glow ignitor. Did that and tried to start it and nothing. When I went to move the truck it looked like fuel came out the pipe. Check to see if it is flooded, check lsn and idle, can someone help me out on this one.
Durango - Speed Passion - Trinity
Gforce Hobbies Raceway
Urban Heat Racing
koopesv is offline   Reply With Quote
Old 07-09-2010, 11:28 AM   #2
portyansky's Avatar
Trader Rating: 54 (100%+)
If fuel is comming out of the pipe it most likely means you are to fat on the high speed needle.
Team Tekno Canadian Team Manager
Team Hitec
portyansky is offline   Reply With Quote
Old 07-09-2010, 03:20 PM   #3
Default re
first;take out the plug and check it with your ignitor if it glows good,then cover the engine with a cloth or paper towel unhook the pressure line from the pipe or tank then crank the motor over for aminute to blow out excess fuelreinstall the glow plug try to start it without hooking the pressure line if it starts hook the pressure line back up then
toofless is offline   Reply With Quote
Old 07-09-2010, 08:22 PM   #4
koopesv's Avatar
thanks fellows gonna try those ideas, let you know the results
Urban Heat Racing
porting for a picco .28?? KEITH Nitro Off-Road 28 07-09-2008 09:52 AM
