Old 07-09-2010, 09:52 AM   #1
lewis666's Avatar
Send a message via MSN to lewis666
Default how to get a longer run time?
hi there,
i was racing last night and i got into the a-final with a 13 minutes final. and i had to have two stops because my engine doesn't have a very good fuel mileage and i did not finish very well because it everyone else only had one stop. but how can i improve it?
many thanks
lewis
Durango DEX410R, BCE Losi 8ight 1.5 (radical 621t), Durango DESC410R on the way!
radical engines- www.gotnitroonline.com
Got nitro team driver
lewis666 is offline   Reply With Quote
Old 07-09-2010, 09:56 AM   #2
mr240's Avatar
Trader Rating: 61 (100%+)
Smaller restrictor and lean that sucker out. LOL.
mr240 is online now   Reply With Quote
Old 07-09-2010, 10:01 AM   #3
K_B
K_B's Avatar
Trader Rating: 69 (100%+)
Alot has to do with tuning. But running a smaller restrictor helps. The smaller restrictor will suck in less air, which means you have to also restrict the fuel intake (lean it out). A proper exhaust pipe can also be critical. I'm still trying to figure out where to start on finding the proper pipe myself.
K_B is offline   Reply With Quote
Old 07-09-2010, 10:08 AM   #4
fatdaddy's Avatar
i would say that throttle control is most important. the less time you spend spinning the wheels the less fuel youre using
HPI Racing - Hot Bodies - D8 Army!
**Team Terribles** (Answer RC, Fastlane Graphix, Caster racing, M2C Racing, and Dialed Inc!)
fatdaddy is offline   Reply With Quote
Old 07-09-2010, 10:14 AM   #5
blktransam's Avatar
Trader Rating: 59 (100%+)
a smaller venturi helps to an extent. if you go to small you may find your self using more throttle to do the same thing a size larger venturi did with less throttle...make sense? also throttle control-clutch-clutch bell-tires-pipe- ALL contribute to fuel milage...if you find you are alway spinnging the tires go up on the clutch bell or even down on the clutch spring...OR drive smoother spinning tires is wasting fuel and wasting tires...
-Ryan Klemme
NemoRacingUSA.com,Beta tires,Agama, Triton Engines, Rocket Graphics, Byron Fuels, RcRenew, Major Art & Hobby, BuKu Products,
Midwest team manager for Nemoracingusa
Owner of Midwest Rc Tour
blktransam is offline   Reply With Quote
Old 07-09-2010, 10:51 AM   #6
Maximo's Avatar
how big is your idle gap ?
Maximo is offline   Reply With Quote
Old 07-09-2010, 02:53 PM   #7
traxxastar21's Avatar
lean her out
JATO "Jet Assisted Take Off"
traxxastar21 is offline   Reply With Quote
Old 07-09-2010, 04:10 PM   #8
blade954's Avatar
Trader Rating: 23 (100%+)
Could be a number of factors ...
What engine and pipe combo, And what insert.
What clutch set up are you using.... What % nitro do you run.
How old is your engine ( how many liters through it).
Like other have said the insert will help to a point but some times going smaller can cost you more, I would look at your hole package maybe a pipe change as this could be the governing factor some pipes are more fuel efficient than others and they can make quiet a difference. Best place to start is your local club is anyone running the same as you are or are they running similar and get better run times, They are the people to ask as they are there and can see your problem in person and maybe give you advice you need.
blade954 is offline   Reply With Quote
Old 07-09-2010, 04:19 PM   #9
Suspended
Trader Rating: 202 (96%+)
run more fuel line and also run 2 big fuel filters with the filter taken out, i run a go engine and a v-spec, 13 to 14 minutes runtime! sounds stupid, but it helps!
inferno13 is offline   Reply With Quote
Old 07-09-2010, 05:14 PM   #10
JAMMINKRAZY's Avatar
Trader Rating: 17 (100%+)
Unless you are following the rules of a 125cc fuel capacity. I personally try to keep my tank capacity legal even when they aren't teching it or even have a rule for it. Helps when you go to a race where they are teching. You already know you have a legal fuel capacity, and all of the practice you have done is on a legal tank. You know how long you can run on a legal tank, so figuring out a pit strategy is much easier.
Honestly fuel mileage has many variables to it. One of the biggest that most people overlook is the driver. Throttle control is the single biggest fuel mileage factor. Other factors are engine, restrictor, tune, pipe, plug, clutch, gearing, weather conditions, etc...
If you know your tune is spot on or at least very close, you could try a smaller restrictor. Also depending on what engine/pipe combo you are running, you may benefit from a pipe change. Knowing the engine/pipe/restrictor combo would help.
-Koby Kubrin-
Thanks to my Sponsors:
Serpent America | Team Novarossi | Desoto Racing | Race AKA | Ridgeway Bodies
JAMMINKRAZY is offline   Reply With Quote
Old 07-09-2010, 05:30 PM   #11
Suspended
so you cant run fuel filters? hmmmm......who's the idiots that thought that rule up?
Old 07-09-2010, 06:38 PM   #12
blktransam's Avatar
sure u can run a fuel filter...as long as you are in specs of 125cc for buggy and 150cc for truggy...also jammin I said "driver smoother"
-Ryan Klemme
Old 07-09-2010, 06:47 PM   #13
jmaxey51's Avatar
+1, well said
jmaxey51 is offline   Reply With Quote
Old 07-09-2010, 07:21 PM   #14
Quad Racer 34's Avatar
Trader Rating: 4 (83%+)
Drive an electric car (any) for a couple months and then drive your nitro. It helped me tremendously for throttle control. I drive my nitro like an electric now. Therefore, being smoother on it I can lean it out more and get a little bit more runtime as well. Rather than blipping and wasting fuel. The more blipping the less your engine will get "loaded up" with fuel. If you drive it real smooth like an electric with that same "blipping" tune, you will notice it will feel richer through the power deliver. So you can lean it more. Works for me. Hope this made sense
Dylan Gerard
Serpent - Desoto Racing - Picco - AKA - Hitec - RC Addictions Products - Tekin - VRP - Avid RC - SMC - MIP - SkipGear - The Ohio RC Factory
Quad Racer 34 is offline   Reply With Quote
Old 07-10-2010, 12:05 AM   #15
lewis666's Avatar
hi there,
many thanks for all the replies. i am currently running a picco p3 .21 engine with an edit pipe:
http://www.rc-edit.com/piw.php?partN...x=ED10&lang=en
the problem is my picco does not have restrictors. but my new engine, my radical 621t should be here next few weeks and i think that has restrictors.
but someone mentioned glow plugs, but how can that help? i am currently got a medium glow plug?
many thanks for the replies
lewis
How to solder correctly (a not so brief lesson) marine6680 Radio and Electronics 542 06-07-2017 06:14 PM
Need help to get back into this hobby.... Xroger Singapore R/C Racers 6 12-05-2009 07:30 AM
How to really improve your company's market share in the R/c community Wild Cherry Electric On-Road 89 03-17-2008 06:06 AM
How to make fans on a switch... XrayFK05 Electric On-Road 17 09-01-2005 03:38 AM
