air filters
air filters
ok heres my question do you guys, run your outerfilters dry when the track is dusty and dry ? because when i was, running at my track my filter had guck all over it and my engine, flamed out all the sudden and my engine started to run richer .
so do you think i should just run, my outfilter dry because i think thats what is causeing my flame out and clogging up my engine.
same here.. A little trick I learned from someone on here is oil the inner filter and then oil the inside of the outer filter. So the dust wont stick to it and the little bit that does get through it wont make its way through. I've been doing it ever since.
oh ok i get it. but is it ok to run the outer filter dry on a dry track ?
i do run a inner filter too or, do you have to have the outer filter oiled ?
re
you can run the outer filter dry,ihave for along time,but like he said turn the outer filter inside ot and oil it a little then turn i right side out and install it I am gonna try this
