Old 07-07-2010, 07:11 AM   #1
ferhobby's Avatar
Default help setup hyper 8.5 for MEX NAT
hello guys could you help me with my set up
is for this track in Guadalajara city NAT next weekend
+ YouTube Video
http://www.youtube.com/watch?v=-itD2...layer_embedded
my set up actualy is:
Car-Hyper 8.5
.21 JL Force 4 tanks
clutch original (aluminium)
13t ventilate
Fuel 30%
Tires-VP
pipe hyper (come with kit car)
servos airtronics 94931
Front
5000 diff fluid
2.3mm sway bar
+3deg in superior arm
-2deg camber
+1.5deg toe out
14mm shock w/gray spring
mod piston 4 holes 2/ 1mm , 2 /1.3mm
45wt oil
shock tower 3er hole inside to outside up holes
inside hole on arm
middle hole on ackerman
20deg castor block
8 anti-squatc
original shock with cream spring
5mm spacer
Center
7000 diff fluid w/spider diff
13t clutch bell
stock spur
Rear
2000 diff fluid
2deg anti squad
-3 deg camber
-3deg toe in
-2.6mm sway bar
-middle wheel base
-shock frist hole inside top holes on tower
-shock 14mm w/gray sprins
-37wt oil mix associated oil
-outside hole on arm
-mod piston 4 holes 2/ 1mm , 2 /1.3mm
-wheel hub
up frist hole uotside up
an down brace up hole
what can change for be more stable and be more fast in curve
i have dude too in:
1- what clutch paste use??
have 3 option
ofna black fiber,
ofna red fiber,
VP-pro aluminium
have spring .7,1, 1.1
2- what ride height in chassis F/R?
thank you
fer
ferhobby is offline   Reply With Quote
