Old 07-06-2010, 10:05 AM   #1
Trader Rating: 15 (100%+)
Default wiping out clutch bearings
I'm using werks clutchs and i'm going through clutch bearings in 2 heat races.I've got plenty of play in the clutch bell.Going to try some ceramic's to see if that works .Don't understand why this is happening.I figured there would be less heat generated by using werks,But i know that this sucks and will cost me an arm and a leg if i can't get this resolved.I really like the clutch but not if it's going to do this to me everytime!
blacksunshine is offline   Reply With Quote
Old 07-06-2010, 10:08 AM   #2
gear mesh..........
TLR - Spektrum - Horizon - TLR 8ight 4.0 - TLR 8ight-T 4.0 - TLR 22 4.0 - Orion
token is offline   Reply With Quote
Old 07-06-2010, 10:10 AM   #3
morgoth's Avatar
Can't you get rid of the play with shims?
morgoth is offline   Reply With Quote
Old 07-06-2010, 10:22 AM   #4
On clutch bearings you are just better off paying more for the ceramics.
one8updragracer is offline   Reply With Quote
Old 07-06-2010, 10:28 AM   #5
I don't think ceramics will solve your problem. If they are going out that quickly there is an issue. Possible causes are wrong mesh(too tight), worn/loose spur gear, wrong shimming, mud or dirt in the teeth of the spur gear/bell, engine bearings going out, chassis flexing too much(usually a cracked chassis), and heat related problems. That's all I can think of off the top of my head.
3DRCRACER is offline   Reply With Quote
Old 07-06-2010, 10:31 AM   #6
motomatt's Avatar
Originally Posted by token View Post
gear mesh..........
Always check mesh in at least 4 places on the spur gear. Some spur gears have been found to not have the centers located correctly. This isn't common, but it does happen.
Does your crank have any runout?
And also check gear alignment.
motomatt is offline   Reply With Quote
Old 07-06-2010, 10:52 AM   #7
the mesh is free rolling with no sticky spots.everytime i shim the bell out to where it has a very little play it does the same thing.lose or or little play same affect on the bearings.Is mesh being to lose just as bad as being to tight?
Old 07-06-2010, 10:56 AM   #8
Slider30250's Avatar
The clutch springs might be too stiff causing your clutch to slip and generate too much heat. I had the same problem with burning out clutch bearings in my 8ight T and it was because of spring that were just too stiff.
Anyone can crash, I crash with style
Mugen MBX6R/Airtronics M11X/Ninja Engines/Sidewinder Fuel/EB Mods
Slider30250 is offline   Reply With Quote
Old 07-06-2010, 11:04 AM   #9
back to the top werks clutchs have 1 spring set flush with the flywheel nut.
Old 07-06-2010, 11:08 AM   #10
What I was saying is that spring might be too strong and not allow your clutch to engage soon enough to keep from slipping at low to mid RPM's. That would generate more than enough heat to destroy a set of clutch bearings.
Old 07-06-2010, 11:49 AM   #11
Trader Rating: 47 (100%+)
Take that Werks clutch set-up and throw it in
the trash. Get a three or four shoe clutch set-up
and your problems with clutch bell bearings will
go away.
rageworks is offline   Reply With Quote
Old 07-06-2010, 11:57 AM   #12
Make sure motor is mounted square to the spur gear.
bacchus is offline   Reply With Quote
Old 07-06-2010, 12:15 PM   #13
Hey rageworks do you know for a fact has this happened to you with the werks or just giving advice?
Old 07-06-2010, 01:10 PM   #14
hdcruzer's Avatar
Are you running that clutch on a werks motor? I had problems with clutch bearings when I ran a werks motor changed over to a Alpha and havnt had a problem in nearly a gallon. It also has to do with alighnment. make sure your motor is square and not cocked, If its cocked even a little it will eat bearings also.
Ofna Late Model-Losi 350-Losi RE 10-Hobbico CS170s
Coldfusion Fuel
Henchman Racing
hdcruzer is offline   Reply With Quote
Old 07-06-2010, 02:18 PM   #15
merdith6's Avatar
Default Maybe
It could also be the crankshaft is worn down so the clutch bell wobbles like crazy. It happens on mostly older engines or when you've had bearings sieze up or go out and the crank is out of round as a result. If it's the werks clutch with the adjustable spring that goes over the crank, it can loosen up while driving, if it's the newer werks clutch that's like the losi system it should be fine...give the gear mesh a bit of clearance as chassis flex can bind up the mesh if too tight....
Mad Dog drives a Mugen MBX-7, Novarossi engines, Clockwork Racing, Futaba radio, AKA/Proline Tires
merdith6 is offline   Reply With Quote
8IGHT 2.0! BAUSTIN Nitro Off-Road 14679 09-12-2015 07:58 AM
