Old 07-05-2010, 07:40 AM   #1
Default diff oil question?
hey guys. I have had to pull my diffs apart a couple of times for various reasons, and my question is. Is the diff oil ment to turn into a grease like substance after a while? Every time i redo my diffs, the clear oil that i put in them has turned into a thick black grease, is that normal?
thanks
Krupt is offline   Reply With Quote
Old 07-05-2010, 07:46 AM   #2
travis4380's Avatar
Trader Rating: 17 (100%+)
How long are you waiting to pull them apart? If you run the diff fluid to long it will turn black.
Tekno SCT 410
Tekno EB48.2
Tekno NT48
http://www.showmerc.com/phpBB3/index.php
travis4380 is offline   Reply With Quote
Old 07-05-2010, 07:52 AM   #3
it's normal
"You are not understanding the fundamental principles of my fragmented personality"
Mugen
dreaux is offline   Reply With Quote
Old 07-05-2010, 07:56 AM   #4
last change was about 4lts ago.
So if its normal, a thinner diff fluid will just turn into a less dense grease?
thanks again
Old 07-05-2010, 11:20 AM   #5
If your diffs were filled with grease and they have not been cleaned carefully and then you filled them with fluid. Fluid may turn to greasy thing...
#WeAreAE The Forum - RCTen.com
My R/C Blog - MyRCBox.com
Sylvain is offline   Reply With Quote
Old 07-05-2010, 03:52 PM   #6
Slider30250's Avatar
If the oil has turned black then it's burned, you should be changing the diff fluid out after every race weekend or every half gallon (2 liters) to maintain consistent diff action and protection to the diff gears.
Anyone can crash, I crash with style
Mugen MBX6R/Airtronics M11X/Ninja Engines/Sidewinder Fuel/EB Mods
Slider30250 is offline   Reply With Quote
Old 07-05-2010, 08:15 PM   #7
merdith6's Avatar
Default Hmmmm
It depends on the car. I had a kyosho that had softer gears inside the diff and they changed the diff oil quickly, but if the gears are hard steel then every 4-5 race days, Mugen, etc...... It's ok for the oil to turn a bit, or you could go a bit thicker on the oil....Especially in the center diff......
Mad Dog drives a Mugen MBX-7, Novarossi engines, Clockwork Racing, Futaba radio, AKA/Proline Tires
merdith6 is offline   Reply With Quote
Diff oil question Doxiedad Electric Off-Road 7 05-31-2010 08:20 PM
