Old 07-04-2010, 06:16 PM   #1
kyle133's Avatar
Default stalling problems
hey guys i have a friend who is struggling with his nitro buggy. i thought for sure it was an airleak, but there is no wet dirt spots around any parts of the carb or motor. he desribles his problems as this:
so i got a d8 and run a werks motor and when im racing it stalls out about 3-4 minutes into every race. idle is good maybe even alittle high going to the track to figure it out and wanna have a list of stuff to try. has new fuel tank, clutch shoes, springs and bearings.also checked to make sure the servo doesnt close the carb. any help will be apreciated.
what you guys think?
ACTION HOBBIES KINGSVILLE
MT POCKETS RACING
kyle133 is offline   Reply With Quote
Old 07-04-2010, 06:22 PM   #2
werks b5 carb?
Andy
TLR 22 Rear & Mid
Superior Hobbies - RC King - Tyrant RC Graphics
Holeshot Raceway www.HSRaceway.com
SCRC Spacecoast RC www.spacecoastrc.com
02maxima18 is offline   Reply With Quote
Old 07-04-2010, 06:27 PM   #3
kyle133's Avatar
no he was running a GO Tech 7 port carb. the werks carb he has, the slide was sticking real bad.
MT POCKETS RACING
Old 07-04-2010, 06:36 PM   #4
jammin32j's Avatar
Tell him to check the clunk in the tank. It sounds like mine did when it fell off. I fought it all day long with it. I got home that night and dumped the rest of the gas out and the clunk came with it. And mine had a new fuel tank too.
VP Pro, Agama
Hitec-7955's, 3Pk----AKA Racing Tires
Absolutehobbyz.com____Dirtrc.com
O'Donnell, D.I.R.T. R/C ultimate Tire Gluer
Jeremy Davis
jammin32j is offline   Reply With Quote
Old 07-04-2010, 06:41 PM   #5
kyle133's Avatar
he bought a new tank. and to be safe he dumped out his tank and looked for the clunk. it was still where its suppose to be.
MT POCKETS RACING
Old 07-04-2010, 06:43 PM   #6
I have the same problem??
Murdered 5T is offline   Reply With Quote
Old 07-04-2010, 07:20 PM   #7
jammin32j's Avatar
Make sure the fuel line that is connected to the clunk is not to long. If it is it might me causing the clunk to get caught up in the middle of the tank. Did you notice if the engine is going lean before it quits?
VP Pro, Agama
Jeremy Davis
Old 07-04-2010, 07:24 PM   #8
Try to turn the idle screw in 1/4 to 1/2 and see how she goes.
one8updragracer is offline   Reply With Quote
Old 07-04-2010, 07:26 PM   #9
moeman's Avatar
Trader Rating: 26 (100%+)
Get rid of that POS "GO" carb. JEEEEEUNNNKKKK
moeman is offline   Reply With Quote
Old 07-04-2010, 07:36 PM   #10
808gx7r's Avatar
if its a gx carb... its good. same o.s or novas, works fine...
808gx7r is offline   Reply With Quote
Old 07-04-2010, 07:54 PM   #11
DPowers's Avatar
Trader Rating: 79 (100%+)
How many gallons on the motor and which werks is it, and how does the motor run doing warm up does it die when ur own the throttle or when letting off.
DPowers is offline   Reply With Quote
Old 07-04-2010, 08:04 PM   #12
Default stalling
its a b7 and has 4-5 gallons threw it stalls when i let off the throttle
ur2slw is offline   Reply With Quote
Old 07-04-2010, 08:09 PM   #13
DPowers's Avatar
First Check the rear bearing then i would say check the compression it could be lossing compression when it gets up tp temp u can idle it up about 2-3 hrs and see if that helps.
Old 07-04-2010, 08:57 PM   #14
Suspended
Trader Rating: 5 (88%+)
My B5 did the same thing 5 minutes into a 7 min quailifier and flamed out everytime, changed gaskets and springs and like magic work perfectly. When the engine does get up to temp will it idle? if not then maybe time for a new p/s or a pinch job, replace bearings with ceramic if you have to go in it.
carlam is offline   Reply With Quote
KYOSHO GXR28 - Tuning problems :( Lawson1024 Nitro On-Road 23 06-10-2010 04:51 PM
Ninja jx .21 stalling troubles ka41 Nitro Off-Road 22 03-09-2010 09:08 AM
Kyosho GXR28 - Tuning Problems :( Lawson1024 Nitro Off-Road 12 09-16-2008 03:44 PM
Big, mysterious engine problems. Need HELP! stefan Onroad Nitro Engine Zone 42 06-21-2007 10:39 PM
