Old 07-04-2010, 01:46 PM   #1
Default braking issues
truck stalls when i hit brake and running super slow.. how do i tune?
savagexl-69 is offline   Reply With Quote
Old 07-04-2010, 02:02 PM   #2
draggin87's Avatar
Trader Rating: 32 (100%+)
check your clutch bearings, or adjust you idle higher
Dialed Hobbies~~~~VP-PRO~~~~FZRC
Serpent 811 2.1, O.S. Speed XZB.
Serpent SRX2 MM, Tekin RS, Trinity D4 17.5 Certified
Scott Blaney
draggin87 is offline   Reply With Quote
Old 07-04-2010, 02:04 PM   #3
Is the throttle linkage keeping the throttle open at neutral and when you apply the breaks it fully closes the throttle of which the idle stop screw is set to where the idle gap is too small?
bacchus is offline   Reply With Quote
Old 07-12-2010, 02:26 PM   #4
guntek18's Avatar
Trader Rating: 16 (100%+)
Cool
weak clutch springs.........still engaged at low idle. clutch will grab motor and bring it to a stop.
guntek18 is offline   Reply With Quote
Old 07-12-2010, 02:46 PM   #5
jjshbetz11's Avatar
Does the mill run hot recently? Check springs and the bearings of the clutch.
Losi 8ight 2.0 RR
Werks Racing
Hi-tec
Spektrum
jjshbetz11 is offline   Reply With Quote
Heat Issues with my Losi 8ight 2.0E LosiRox Electric Off-Road 22 09-22-2009 08:39 PM
Serious Diff Issues in my TC4 Ride1226 Electric On-Road 13 06-23-2009 06:21 PM
Losi e 8ight break issues ATMHOBBY Electric Off-Road 25 11-05-2008 08:16 PM
Braking... Nautilian Electric On-Road 24 11-13-2006 11:45 AM
