stalling problems
stalling problems
hey guys i have a friend who is struggling with his nitro buggy. i thought for sure it was an airleak, but there is no wet dirt spots around any parts of the carb or motor. he desribles his problems as this:
so i got a d8 and run a werks motor and when im racing it stalls out about 3-4 minutes into every race. idle is good maybe even alittle high going to the track to figure it out and wanna have a list of stuff to try. has new fuel tank, clutch shoes, springs and bearings.also checked to make sure the servo doesnt close the carb. any help will be apreciated.
what you guys think?
werks b5 carb?
Andy
Andy
no he was running a GO Tech 7 port carb. the werks carb he has, the slide was sticking real bad.
Tell him to check the clunk in the tank. It sounds like mine did when it fell off. I fought it all day long with it. I got home that night and dumped the rest of the gas out and the clunk came with it. And mine had a new fuel tank too.
he bought a new tank. and to be safe he dumped out his tank and looked for the clunk. it was still where its suppose to be.
I have the same problem??
Make sure the fuel line that is connected to the clunk is not to long. If it is it might me causing the clunk to get caught up in the middle of the tank. Did you notice if the engine is going lean before it quits?
Try to turn the idle screw in 1/4 to 1/2 and see how she goes.
Get rid of that POS "GO" carb. JEEEEEUNNNKKKK
stalling
its a b7 and has 4-5 gallons threw it stalls when i let off the throttle
My B5 did the same thing 5 minutes into a 7 min quailifier and flamed out everytime, changed gaskets and springs and like magic work perfectly. When the engine does get up to temp will it idle? if not then maybe time for a new p/s or a pinch job, replace bearings with ceramic if you have to go in it.
