Old 07-03-2010, 01:24 PM   #16
Trader Rating: 12 (93%+)
ohh ill probably put a new set on after ever heat or so. I got few 1lbs bag full of them haha.
rcdude236 is offline   Reply With Quote
Old 07-03-2010, 01:33 PM   #17
Trader Rating: 36 (100%+)
That'll work, cuz rubber band man can.
NitroFreak2 is offline   Reply With Quote
Old 07-03-2010, 01:54 PM   #18
Ya. but ill check them before every run. You can see when they are gonna break, they start tearing apart a little.
Old 07-04-2010, 10:15 AM   #19
One msitake many people make is thinking a return spring/rubber band needs to snap the throttle closed in case the battery gets disconnected, or the switch fails or a wire breaks, etc. If it will close the throttle MOST of the way the vibration of the engine running will free everything up enuff for it to finish the job.
Ed M.
bentgear is offline   Reply With Quote
Old 07-04-2010, 10:21 AM   #20
Ed M.
Ya i dont have it very tight. i mean its just enough to bring it back, if its 1/4 or 1/2 thorrtle im fine with that. Im still young and really confident in my running!
install a throttle return spring Sylvain Nitro Off-Road 32 05-05-2012 11:32 AM
Throttle Return O-ring tiger200350 Nitro Off-Road 17 04-07-2010 05:31 AM
Throttle Return Spring Problem helgso Nitro Off-Road 17 08-10-2009 11:05 AM
Throttle return spring on 1/8 buggy RGraves Nitro Off-Road 40 03-27-2009 05:41 AM
Throttle Return Springs: Who uses them? WeatherB Nitro On-Road 7 04-19-2005 06:48 AM
