Old 07-02-2010, 01:19 PM   #1
tc5 man's Avatar
Default inverter for my heat gun
i have a question i seen this 800, watt inverter at pep boys and was wondering if it has, enough power for a heat gun ?
im gone to use it on my engine.
Old 07-02-2010, 01:23 PM   #2
fatdaddy's Avatar
how many watt is your heat gun?
HPI Racing - Hot Bodies - D8 Army!
**Team Terribles** (Answer RC, Fastlane Graphix, Caster racing, M2C Racing, and Dialed Inc!)
fatdaddy is offline   Reply With Quote
Old 07-02-2010, 01:25 PM   #3
markr04's Avatar
Your heat gun is probably about 400 watts, so it should be fine. But you're already gone to use it?
Xray 808 2010 Spec - O.S. V-Spec Speed - Airtronics M11-DSSS
Losi 8ight-T 2.0 - RB Killer 9 - Airtronics M11-FHSS-2
Losi XXX-CR - Tekin RS / Novak Ballistic 13.5 - Airtronics M11-FHSS-2
markr04 is offline   Reply With Quote
Old 07-02-2010, 01:32 PM   #4
jammin32j's Avatar
I have two heat guns and one is rated at 1000 watts and the other is rated at 1200 watts. Double check your watt rating before you get an inverter.
VP Pro, Agama
Hitec-7955's, 3Pk----AKA Racing Tires
Absolutehobbyz.com____Dirtrc.com
O'Donnell, D.I.R.T. R/C ultimate Tire Gluer
Jeremy Davis
jammin32j is offline   Reply With Quote
Old 07-02-2010, 01:33 PM   #5
tc5 man's Avatar
i have been using the heat gun, with a extention cord but at my track there is never enough plug outlets so, thats why i need a inverter il just hook it up to my car battery.
its a pretty new engine stil tight lol.
i checked on the back of ..the heat gun and you can set it to 1000w or 120 v.
i only have a low heat setting and , a hot heat setting i have to use the hottest setting . but i use 120 v setting.
Old 07-02-2010, 01:40 PM   #6
tc5 man's Avatar
heres my heat gun that i use
Old 07-02-2010, 01:41 PM   #7
casterdriver's Avatar
just a little advice on inverters........ get one a little larger than what u need....... the ratings on those things especially the cheeeepy ones are kinda over-rated. Typical for stuff like that though since most of it is chinese and price-point stuff.
Mugen MBX7/WERKS CRE-B6,Stock B6,Stock B2/Werks 2013,2057,2058
RC10GT2-FT, Dynamite Platinum .12
VP-Racing Powermaster 20% and 30% Race Fuel
Official NON-EXPERT
casterdriver is offline   Reply With Quote
Old 07-02-2010, 01:48 PM   #8
tc5 man's Avatar
ok how about this one than ? its a good price also.
Old 07-02-2010, 01:56 PM   #9
fatdaddy's Avatar
also, if i remember correctly the rattings on inverters are for the peak power output. so if that one youre looking at is 800w peak, it will probably be 400w constant.
if your heat gun is 1000w. you need at least a 1100w constant power inverter.
this is probably about what you need: http://www.amazon.com/Whistler-PI-12.../dp/B000621X26
"1200 Watt continuous power, with 2400 Watt peak power"
Old 07-02-2010, 02:04 PM   #10
tc5 man's Avatar
ok yea that looks like a good one and you get free shipping.
heres the question though can, i switch my setting to 120 v and put it on the hot setting and still get, warm enough to 200 for my engine ?
because i have tried the low heat, setting and even when i tryed the 1000 w setting it was too cool ? 1000w on the hot setting i think would be too hot.
Old 07-02-2010, 02:10 PM   #11
Frank L's Avatar
Trader Rating: 148 (100%+)
I use this heat gun http://www.amainhobbies.com/product_...-Watt-Heat-Gun and it's only 300 watts and it gets twice as hot. A quality heat gun will be more efficient.
Old 07-02-2010, 02:23 PM   #12
tc5 man's Avatar
man thats a nice one and the head isnt big , my full size car has a plug outlet in the rear of my truck and, it says 115 v ac and 150 w so whould that heat gun your remmending work with that ?
and also does it have a low meduim and high heat setting ?
Old 07-02-2010, 02:50 PM   #13
Frank L's Avatar
It does have a low and high setting. I will have to plug it into the one in my suv and see IDK.
Old 07-02-2010, 02:57 PM   #14
Frank L's Avatar
Man my plug in the SUV only ways 100 watts and I paid a butload for that big fancy "L" on the front. But nope it wont fire the heat gun. I amsl looked at the side of the heatgun and it saws 1300 watts so maybe amain's site is wrong.
Old 07-02-2010, 03:12 PM   #15
kja812's Avatar
1200W @ 12V = 100 amps....that is why your vehicle doesn't have high power outlets...the wiring needs to be quite heavy. Keep the power leads as short as possible or you will loose a lot of power in the input wiring to your inverter.
As long as the temp. of the air coming off the heater is well over 200, it will get your engine up to temp....eventually.
kja812 is offline   Reply With Quote
Houstons Engine Service H.E.S. houston Offroad Nitro Engine Forum 8821 06-17-2017 12:29 PM
DuraTrax IntelliPeak ICE DC Competition Charger billwilner Radio and Electronics 1944 04-10-2014 04:23 AM
engine warmer qustions bigguyrc8 Nitro Off-Road 56 02-17-2010 08:57 AM
starter box for 8t nitro neil Nitro Off-Road 29 07-12-2008 03:55 AM
