Old 07-02-2010, 05:52 PM   #16
Marcus Falconie's Avatar
Originally Posted by joejo View Post
if i just plug the fuel to carb line and blow in the pressure line, can i diagnose a pressure leak properly this way?
No you should change your exaust gaskets if they are bad I change them all the time and change your fuel line, this stuff is real inexpensive and helps keep your motor running smooth. One other thing is how old is your motor and does it have any compression?
Marcus Falconieri
2011 Xray 808
Torco Racing Fuels
KBRL Nitro Series
www.youtube.com/gsadvanced
Marcus Falconie is offline   Reply With Quote
Old 07-02-2010, 05:57 PM   #17
well the exhaust gaskets are new and the engine was used when i got it sooo...
i was told it didn't have much more than a gallon thru it, but since then i have put a gallon thru it. compression is getting a bit lower than new, but still seems good.
like i said though the change happened in the middle of a run. not after hours of bashing time and time again. from startup, about 1/2 tank later it acted up.
joejo is offline   Reply With Quote
Old 07-02-2010, 06:22 PM   #18
It could also be your exaust gaskets on your motor or your pipe or a broken fuel line or exaust pressure line most of the time this will cause your motor to go lean because of the lack of pressure but I have seen it cause the motor to just act bad. When ever I have a sudden tune issue and it is not the plug like Joe says I would start to look for pressure leaks.
for what ever reason i think my tuning is just crap right now. At least i hope that is what it is.
Would a bad fuel tank make your engine run rich??? I don't see how, as a leak would make it run leaner.
"You are not understanding the fundamental principles of my fragmented personality"
Mugen
dreaux is offline   Reply With Quote
Old 07-02-2010, 10:24 PM   #19
Depends if you tuned it to the leak and then with crud etc it seals at the leak, which would then make your engine run rich.
Kev Lewis,
I'd like to thank my personal Sponsors :-AKA Tyres Australia, Ryper Hobbies and Just Hobbies
The Gear :- Associated RC8 B3 powered by OS Engines
Soapy is offline   Reply With Quote
Old 07-03-2010, 04:52 AM   #20
Had this happen two weeks ago. Found a small and I mean small peice of gasket in the fuel nipple on carb, did a good cleaning and ta da, it's all good now. It's the little things that drive me nuts. Then again it don't take much.
The Working Man is offline   Reply With Quote
Old 07-03-2010, 07:56 AM   #21
Trader Rating: 35 (100%+)
Is the carburetor slide opening all the way?
Hobbs263 is offline   Reply With Quote
Old 07-03-2010, 09:00 AM   #22
should i take the copper shim out of my ninja when running 20%? Nevermind, that doesn't make sense. It still does the same thing when i run it with 30%
Mugen
Old 07-03-2010, 09:35 AM   #23
I think you just solved your problem. If you are running 30% nitro or if you broke your motors in with 30% you should never go down with the % of nitro you can go higher Hopes this help cause you dont want to go elec.
RCNINJA is offline   Reply With Quote
Old 07-03-2010, 11:17 AM   #24
if your referring to me, then yes.
Old 07-03-2010, 05:11 PM   #25
well i tried the new plug and the clean air filter with no improvement. it still needs to be screwed in all but 1 turn to run good. i have no idea what happened.
Old 07-03-2010, 06:21 PM   #26
RUNNINONMT's Avatar
how are your clutch shose and springs. and if it runs good one turn in how hot is it gettin, hows the smoke, power, and sound
RUNNINONMT is offline   Reply With Quote
Old 07-03-2010, 06:26 PM   #27
went to the LHS and bought a new D sized glo ignitor. My old one was cruded up and the spring was broken. Bought new oddonnel plugs. So far my problem is solved. Also the pipe i was using, the nipple on it has partial blockage.
Mugen
Old 07-03-2010, 06:28 PM   #28
it runs and sounds good. its also still blowing plenty of smoke. the temp is a bit higher but not too high, like 270ish. its just wierd that it went completely out of tune by a full turn in the blink of an eye. something happened but what the heck was it. the clutch shoes and springs are new they have about 10 tanks on them and the bell is also new.
Old 07-03-2010, 06:34 PM   #29
RUNNINONMT's Avatar
i'd richen 1/8 turn and run it. sounds like it should be ok, but yeah weird
Old 07-03-2010, 06:34 PM   #30
jpalessi's Avatar
Trader Rating: 55 (100%+)
Send a message via AIM to jpalessi Send a message via Skype™ to jpalessi
still sounds like a glow problem to me.. check your glow starter.
Joe Alessi
www.Lucky7RC.com
jpalessi is offline   Reply With Quote
Team Associated B44. Race, Tune and Modify Shadows Electric Off-Road 6171 08-09-2015 07:32 AM
my ninja/vspec experiment, you might be surprised! dreaux Offroad Nitro Engine Forum 227 04-22-2013 10:57 AM
Share your biggest duh or what was I thinking Saber186 Nitro Off-Road 145 07-01-2010 06:55 PM
had a runaway, now what? jeff_ellis_9 Nitro Off-Road 74 06-08-2010 07:41 PM
