Old 07-02-2010, 06:01 AM   #1
Default advice on new RC8T RS. Idle & Temp going crazy.
Hello everyone, My RC8T RS has what i believe is an air leak in its AE pro .28 engine. it idles at 250 and if you even look at the throttle funny it goes WOT.
I use Permatex Ultra copper to seal the base of the carb, backplate and fuel intake nipple. Any ideas?
Suavo is offline   Reply With Quote
Old 07-02-2010, 06:22 AM   #2
MotoGod's Avatar
Trader Rating: 112 (100%+)
Send a message via AIM to MotoGod Send a message via Yahoo to MotoGod
If you already sealed it...then your tune must just be WAY off. I would go back to factory settings and try again.
Scott Pouliot
Current Race Rigs: TLR 8ight 3.0/3.0E/3.0T/22/22-4
Thanks to my 2015 Sponsors: LutzRC, RadioPost, AKA Tires, RC Addition Products, Nitro Pro Fuels
MotoGod is offline   Reply With Quote
Old 07-02-2010, 06:24 AM   #3
Suspended
Trader Rating: 202 (96%+)
sounds like your low end needle needs to be turned counter clock wise a turn or two, if idle falls, adjust idle screw, go back to factory settings and give it a try
inferno13 is offline   Reply With Quote
Old 07-02-2010, 07:46 AM   #4
i actually tried stock settings and low speed got better, but i still got some bad stuttering and high temps on idle. should the low speed and idle needles be sealed as well?
Old 07-02-2010, 07:48 AM   #5
MotoGod's Avatar
I usually pull all the needles and put Green Slime on them and then re-install them. The HSN I yank the housing and seal the bottom of the brass upright to the carb body as well. Just as a precaution.
Scott Pouliot
Old 07-02-2010, 07:59 AM   #6
I only have Teflon tape at the moment. Will that do until i can buy some Green Slime?
Old 07-02-2010, 08:02 AM   #7
MotoGod's Avatar
I wouldn't use tape. If it breaks off and gets inside your carb...it will jam things up or worse it could get sucked into the engine. Might be safe...might not be. Have any light grease or anything? That's all Green Slime really is anyway ;-)
Scott Pouliot
Old 07-02-2010, 08:04 AM   #8
i have some bearing grease. kind of thick but not to bad.
Old 07-02-2010, 08:06 AM   #9
MotoGod's Avatar
Try it. Just use a VERY small amount. You don't need much on those needles.
Scott Pouliot
Old 07-02-2010, 08:07 AM   #10
should it be applied to all needles including High and Mid
Old 07-02-2010, 08:26 AM   #11
MotoGod's Avatar
I just do the high and Low. Mid I wouldn't touch in any way, shape, or form to be honest. lol
Scott Pouliot
Old 07-02-2010, 08:36 AM   #12
ok cool. i'll give it a try this afternoon and post the results. Thanks for all your help
Old 07-02-2010, 07:16 PM   #13
Do-Over's Avatar
Default I have that truck
I have the same truck and mine came with a faulty tank that was sucking air I hear it is quite common check for air bubbles in the lines. Also, IMO unless your a pro. DONT touch the MSN.
Also, check your idle gap so you don't over lean your LSN. I'm fairly new but I've learned this much so far. Hope it helps!
Oh, forgot to add this. My engine(same as yours) runs between 235 and 245 all the time. Your temp might go down as the piston and sleeve start to wear in, alot of pinch causes heat.
Do-Over is offline   Reply With Quote
Old 07-03-2010, 12:02 AM   #14
JsK
JsK's Avatar
The backing plate is leaking around the roto-start.
JsK is offline   Reply With Quote
