Old 07-01-2010, 05:41 PM   #1
limiteded1le's Avatar
Trader Rating: 57 (100%+)
Default Question about MP777 Big Bore Shocks
I have a Kyosho MP777 buggy and want to upgrade to the big bore shocks. My question to you all is do the 777ST-RR velvet big bore shocks fit on the front and rear of my 777 buggy? I have Fioroni shocks towers and lower arm mounts, but do the 61mm rear shocks from the ST-RR fit fine or will my rear end sag too low?
limiteded1le is offline   Reply With Quote
Old 07-01-2010, 06:21 PM   #2
supralative's Avatar
Trader Rating: 16 (100%+)
Send a message via AIM to supralative Send a message via Yahoo to supralative
ST-RR rears will work for the rears, but the fronts will be too long for the buggy front.
Son N.
www.hyperspeedmotorsports.com
www.oklahomanitroclub.com
supralative is offline   Reply With Quote
Old 07-01-2010, 07:51 PM   #3
That's wierd cause I read that the fronts fit fine and the rears are too short? I'm hoping someone has done this set-up or tried it and knows what works and what doesn't.
Thanks for the info supralative
Old 07-01-2010, 08:29 PM   #4
Buggy fronts are shorts
ST-RR fronts are mediums
Buggy rear and ST-RR rears are the longs
You will need the longer stand offs too IIRC.
I used to run the K car shocks but no longer use them.
need a little help... revracer222 Nitro Off-Road 27 07-11-2008 09:46 PM
question about shock springs and oil Mugen MBX-5 Nitro Off-Road 21 11-12-2007 06:27 PM
