Old 06-30-2010, 07:21 PM   #1
hookem34's Avatar
Trader Rating: 17 (100%+)
Exclamation Shimming a clutch bell
Should you put the shims inside the clutch bell then put the screw in or should you put the shims on the outside?
I have my shims on the outside now but the screw keeps backing out or the shims pop over the screw and fall off. Needless to say my clutch bell it getting eaten up pretty bad. Help is appreciated
hookem34 is offline   Reply With Quote
Old 06-30-2010, 07:25 PM   #2
jbright33's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to jbright33
i only put 1 or 2 shims on inside to shim it out away from clutch rest on outside and a small washer so shims dont go over the screw
JESSE BRIGHT
jbright33 is offline   Reply With Quote
Old 06-30-2010, 07:26 PM   #3
jbright33's Avatar
JESSE BRIGHT
Old 06-30-2010, 07:31 PM   #4
toobad4u's Avatar
Trader Rating: 93 (100%+)
I use the Ofna clutch bell shim kit. It comes with the shims, and a large washer/spacer thing that the bolt head screws down flush into. This keeps the shims from going over the bolt head.
I usually put a thin one inside between the inner bearing and the flywheel nut, and the rest on the outside.
Stephen
Mihabi RC Your Hometown Hobby Shop.
(850) 914-2815
toobad4u is offline   Reply With Quote
Old 06-30-2010, 07:31 PM   #5
captain america's Avatar
Hi Hookem. Well OK, first things first: are you using the right size shims? Right size of screw? If you have the right size, the shims shouldn't be able to work their way over the screw.
Shims are used to align the clutch bell with the spur. What vehicle is this for, what clutch are you using, and what engine? Ideally, you want a little bit of back-and-forth play of your clutch bell on the flywheel, and by a little, I mean under 1mm.
Info or pics are always helpful
captain america is offline   Reply With Quote
Old 06-30-2010, 07:46 PM   #6
pinky2252s's Avatar
Send a message via AIM to pinky2252s Send a message via MSN to pinky2252s
Also if your screws are backing out use a drop of low grade thread lock. I find that if i dont, my clutch bell comes off and gets eaten up in like 3 seconds
Procrastinators Unite!.....Tomorrow
Team Terribles
pinky2252s is offline   Reply With Quote
Old 06-30-2010, 07:50 PM   #7
Funking-Awesome's Avatar
Trader Rating: 30 (100%+)
I never use thread lock on my clutch screw. I hold the flywheel tightly with my hand and tighten the screw as much as i can. I have never had a problem doing it this way.
Funking-Awesome is offline   Reply With Quote
Old 06-30-2010, 07:50 PM   #8
hookem34's Avatar
Hey Capt.
It is a Mugen 6T with factory clutch and clutch bell on an Extech .24. I have the movement within .5-1mm.
Old 06-30-2010, 08:03 PM   #9
rc skyline's Avatar
I find it best to shim behind the collet if you have to make adjustments in order to get the bell to line up with the spur, That way you dont have shims everywear near your bearings and falling out every time you replace bearings/ inspect clutch
Then just shim the clutch with required amount of play and good to go
Dave
MUGEN MBX7R & MBX6TR
FUSION X ENGINES By Novarossi
BUKU Power Clutch
MECCAMO FUEL - BETA Tires
www.fusionxengines.com.au
rc skyline is offline   Reply With Quote
Old 07-01-2010, 07:43 AM   #10
Reno's Avatar
Trader Rating: 16 (100%+)
I have the MBX6T. With either the Mugen or the Associated clutch I put 1 shim behind the bell and the rest outside to get proper play. I do put a tiny drop of blue Loctite on the bolt. I have never had problems with this method. Not sure why your shims will get over the bolt. That shouldn't happen if you are using the correct shims. Make sure the shims are correct. You don't want them rubbing the bell either.
Reno is offline   Reply With Quote
Old 07-01-2010, 09:14 AM   #11
merdith6's Avatar
Default Here you go....
Depending on the car, I put one medium shim on the clutch nut, then the bearing bell and bearing, then more shims to give it just a slight ammount of play, very little, then use a cone washer, it will hold everything perfect and extend bearing life....Her is one example, there are several brands....
http://www.amainhobbies.com/product_...-Washer-Blue-6
Mad Dog drives a Mugen MBX-7, Novarossi engines, Clockwork Racing, Futaba radio, AKA/Proline Tires
merdith6 is offline   Reply With Quote
Losi Clutch Bell Bearing problems. l3asher Nitro Off-Road 36 05-16-2010 09:31 AM
have you ever seen a clutch bell get that dark blue/black color? dreaux Nitro Off-Road 24 08-31-2009 05:41 PM
losi 8t 1.0 clutch bell bearings giong out rcmandan Nitro Off-Road 14 04-16-2009 04:32 PM
Clutch Bell Bearings...help binaryterror Electric Off-Road 8 08-02-2006 11:04 PM
