Old 06-30-2010, 06:34 PM   #1
Cory Kerber's Avatar
Default Is this compressor worth it?
I got a coupon to get this compressor for $39.99 and want to know if it's worth it? I would only use it at the track to clean my buggy in between heats, blow off tires etc. I have a home compressor, so this would be strictly track use. Please don't tell me which compressor to buy, i just want to know about this one.
http://www.harborfreight.com/3-gallo...sor-95275.html
Losi 8ight-Novarossi N21R-Hitec Servos-AKA-M11 Spektrum
*TEAM TERRIBLES*
Cory Kerber is offline   Reply With Quote
Old 06-30-2010, 06:38 PM   #2
RUNNINONMT's Avatar
if it had more psi. it would be awsome but for 39.99 get it, it'll dothe job.
RUNNINONMT is offline   Reply With Quote
Old 06-30-2010, 06:59 PM   #3
jeff_ellis_9's Avatar
well I have a 3gal Craftsman compressor I use at home, as well as at the track and its 120psi and works great! The one you linked is 100psi, which is not much less than mine, and for that price it will do the job!
you dont need any more than what I have (120psi) to blow your buggy off.
Team Losi Buggy
GO Tech 5 port RB Mods
AKA
HiTec
Spektrum DX3S
jeff_ellis_9 is offline   Reply With Quote
Old 06-30-2010, 07:03 PM   #4
Trader Rating: 103 (100%+)
Ive had alot of bad luck with Harbor Freight tools, phenumatic and eletrical mostly. For what your wanting i would buy a 20 gallon tank and fill it up before you leave for the track. I used to airbrush with a 20 gallon tank and i was getting about 2 hours of spray time out of it.
jrherald420 is offline   Reply With Quote
Old 06-30-2010, 07:19 PM   #5
Stubbs's Avatar
Trader Rating: 57 (100%+)
Two of the guys at my track have this same one. One burned up after just a few months, the other seems to still be running. The problem is that it takes a looooooooooooooong time to pump back up, and with a small tank, it cycles a lot when blowing off your car.
I've got the 2 gal. Campbell Hausfeld (also from Harbor Freight). The first one lasted about 9 months, then I had to replace it because the motor burned up (glad I paid the $17 for the extended warranty). When this one dies, I'm going to either get a larger compressor, or a higher quality (Senco, Thomas, etc...).
Mike Stubblefield - www.capefearraceway.com
"If you're not racing to have fun, then you're doing it WRONG."
"All you need is WD-40 and Duct Tape. If it moves, and it shouldn't, use the Duct Tape. If it doesn't move, and it should, use the WD-40."
Stubbs is offline   Reply With Quote
Old 06-30-2010, 07:20 PM   #6
NitroXray80809's Avatar
Trader Rating: 24 (100%+)
a guy at my tracks got one works great to blow off the cars would say i would use it all the time but its a good track compressure
Xray XB4 | Ko-Propo | Savox | Hobbywing | SpeedPassion | JC |
Kyosho RB6 | Ko-Propo | Futaba | Turnigy | Orion | JC |
AE T4.2 | Ko-Propo | Savox | Turnigy | ProTek | JC |
NitroXray80809 is offline   Reply With Quote
Old 06-30-2010, 07:58 PM   #7
mudboger07's Avatar
Hey Cory, I bought that same one thinking it woud lbe great for the track but it's not, It will run out of useable air in about 45 seconds, If i had to do it over id get a different one..
Proud Sponsor of a 10 year old.....
losi 8ightB 2.0/DX3S/VSpec* Revo-3.3*mod slash*blade-mcx*axial GC2
Team Nitro** F-14*Team Terribles/Answer-RC
Ken
mudboger07 is offline   Reply With Quote
Old 06-30-2010, 08:27 PM   #8
SpraydbySprague's Avatar
Location: Conducting aggressive board meetings at my local track
Trader Rating: 64 (100%+)
With compressors the more important thing than PSI is the CFM (cubic feet per minute). The higher the CFM the better. If the CFM is too low, the compressor will kick in and take longer to refill the tank and run the tool at the same time. The compressor you are asking about only delivers 0.6 CFM @ 90psi. Way too low. Needless to say the price reflects performance.
How would I describe my holeshots?
Three words...
Ready... Steady... Confetti!!!! (gonna need a new one of those)
SpraydbySprague is offline   Reply With Quote
Old 06-30-2010, 08:33 PM   #9
Thanks for the replies. It sounds like a NO. I just thought for the price i would ask.
*TEAM TERRIBLES*
Old 06-30-2010, 11:45 PM   #10
merdith6's Avatar
Default Hello
I'm not a huge Sears fan, but their compressors are pretty reliable. I have the 2 gallon unit, and have ran the dog snot out of it for about 3 years and no problems. At sears you can get the protection agreement and it helps if anything goes wrong. I used to work there and it makes it easy to get a new one instead of getting it fixed....
Mad Dog drives a Mugen MBX-7, Novarossi engines, Clockwork Racing, Futaba radio, AKA/Proline Tires
merdith6 is offline   Reply With Quote
Old 07-11-2010, 08:49 PM   #11
Is this compressor just as bad? I found it for $40 + $5 shipping, so i thought i would ask. I'm thinking the tank is too small.
http://www.walmart.com/ip/Campbell-H...68393923137773
*TEAM TERRIBLES*
Old 07-11-2010, 08:57 PM   #12
Ive burned 2 of them up just trying to airbrush with it. The first one took only 1 hour, the second one took about a week.
Old 07-11-2010, 09:09 PM   #13
I just got the excact same compressor as you did last night. The one we have has a cfm rating of 2.4 @ 90 psi. The harbor freight one has .6 @ 90 psi.
cfm is the amount of air delivered (cubic feet per minute)
I paid 140$ for mine but i already love it.
"You are not understanding the fundamental principles of my fragmented personality"
Mugen
dreaux is offline   Reply With Quote
Old 07-12-2010, 04:55 AM   #14
I have this same compressor and found it to work very well for rc. And I found mine on sale for 80.00 just shop around .
** Scott's Hooker Service** Craftworld and Action Hobbies**Craco Cryogenics** Hotbodies D8T **Fusion X Engines** Byron Fuels ** Hitec Servos ** Spectrum **AKA Tires**
nothin special is offline   Reply With Quote
Airbrush, Compressor and Lexan Paint Recommendations / Discussion NexusKaiser Singapore R/C Racers 13 11-25-2008 08:00 PM
Is Duratrax full of it? Ongoing problems with ICE chargers gndprx Electric On-Road 30 06-07-2007 12:44 PM
Is buying this 15 dollar air brush kit worth it? adr3naline fix Painting, Designs, Graphics and Photography 9 08-30-2005 05:35 PM
Airbrush, Compressor and Parma Paints ! RCSavant Malaysian R/C Racers 25 11-18-2003 03:05 AM
