Old 06-30-2010, 06:52 AM   #1
Drusillus's Avatar
Trader Rating: 22 (100%+)
Send a message via AIM to Drusillus Send a message via MSN to Drusillus Send a message via Skype™ to Drusillus
Default She's stuck Captain
I have a small issue on my MBX5T chassis.
The engine mount screws from underneath are locked, hard.
I'm trying to remove the engine mount from the chassis and I'm either going to snap my hex driver or the screws are going to strip.
This is a used vehicle I bought so I do not know how the previous over locked them down. For all I know he glued them in
Any tips/tricks to loosen those screws without breaking something?
I suppose I could always just leave them in, but then I'd have no way to adjust mesh if I use different size clutch bells.
tyvm in advance.
Drusillus is offline   Reply With Quote
Old 06-30-2010, 06:58 AM   #2
if they are the stock mounts try to get one out of each if you can, the your move the mount back and forth to loosen the other one.
I hear alot of people have had great success using a heat gun (or hairdryer) on the mounts (make sure you heat the mounts and not the chassis).
If they are that rusted in there slotting with a dremmel might not work. But honestly i would try loosing it up with a wrench and see what happens first.
And if none of that works, break out the drill and drill the head until the cap comes off and you can take the rest of the screw out with plyers.
"You are not understanding the fundamental principles of my fragmented personality"
Mugen
dreaux is offline   Reply With Quote
Old 06-30-2010, 06:58 AM   #3
MotoGod's Avatar
Trader Rating: 112 (100%+)
Send a message via AIM to MotoGod Send a message via Yahoo to MotoGod
Heat em up as much as you can. a Good soldering iron sometimes helps....get it hot and hold it on the head of the screw until it breaks loose. You could always cut a slot in them too and use a big screwdriver to try and get them to break free. Previous owner may have used red loctite?
Scott Pouliot
Current Race Rigs: TLR 8ight 3.0/3.0E/3.0T/22/22-4
Thanks to my 2015 Sponsors: LutzRC, RadioPost, AKA Tires, RC Addition Products, Nitro Pro Fuels
MotoGod is offline   Reply With Quote
Old 06-30-2010, 07:01 AM   #4
Drusillus's Avatar
So heating up the screws with a soldering iron may work huh?
I can give that a try tonight. I've always thought heat would swell the metal and make things tighter. But I've been wrong before
Thanks for the help both of ya!
Old 06-30-2010, 07:18 AM   #5
Applying Heat will break down the loctite, that should help remove screws.
Hobby PRO-USA
Agama A8 / A8T / A8E
Team Strike / Sidewinder
Sirio ExTech
Pro Match Racing
Ramirez24 is offline   Reply With Quote
Old 06-30-2010, 07:20 AM   #6
IF there was locktite used. My bet is rust. Guy sells it, no telling how long it was sitting there.
Mugen
Old 06-30-2010, 07:28 AM   #7
Frank L's Avatar
Trader Rating: 148 (100%+)
If heat does not work then try some penetrating fluid or a blowtorch.
Old 06-30-2010, 10:22 AM   #8
scoopdaloop's Avatar
Trader Rating: 10 (92%+)
Send a message via AIM to scoopdaloop
You need to do some forearm workouts for about two weeks. I'd recommend the extreme hand grips. Get jacked, then attack those damn screws!
Tekno SCT410/OrionR10 Pro + Novak 4.5 Ballistic/Hitec 7955tg
AE B4.2/Tekin RS Pro/D3.5
I'm a tech nerd, watch out son.
scoopdaloop is offline   Reply With Quote
Old 06-30-2010, 10:28 AM   #9
MotoGod's Avatar
I was going to suggest the same. If heat fails...it's probably rusted in there so penetrating oil will help loosen things up. If all else fails....you'll have to drill em out.
Scott Pouliot
Old 06-30-2010, 10:42 AM   #10
jpalessi's Avatar
Trader Rating: 55 (100%+)
Send a message via AIM to jpalessi Send a message via Skype™ to jpalessi
grab your wrench with a channel lock and give it hell. after heating up loctite. if you strip the screw then cut a slot in the screw head w/ a dremel and use a flat head driver.
Joe Alessi
www.Lucky7RC.com
jpalessi is offline   Reply With Quote
Old 06-30-2010, 11:02 AM   #11
Get an easy-out bit, it comes with 2 bits small and big.
1 side of the bit cleans the area it just drills it clean and stuff
The other side is like a thread and you put it in reverse and it pulls it right out.
It only like 30$ for the 2 bits
This has happened on my 8ight buggy before and I used that tool.
Team Losi 8ight 2.0
Team Losi Nitrotec w/ 2013
riverviewrc is offline   Reply With Quote
Old 06-30-2010, 11:03 AM   #12
Forgot to mention this will ruin your bolt you wont be able to use it again.
This way only works if you have a spare bolt ^^
Team Losi 8ight 2.0
Old 06-30-2010, 11:04 AM   #13
Drusillus's Avatar
Gracias for the tips guys!
Old 06-30-2010, 06:07 PM   #14
lowcountrytj's Avatar
Like they said ....heat,but just enough to break it loose.
I use a micro torch and apply heat directly to the bolt/screw for about 10 to 15 seconds...you will see the moisture dissapate from the area and its ready.I have used the heat gun but with the micro torch it narrows down the area being heated...my 2 cents
LOSI 8B--8T///SC10--Im not on a budget,I have a fudget
Team Terribles
Phil Hurd Raceway S.C.O.R.E. Savannah Ga(2nd Oldest RC track in the US)
lowcountrytj is offline   Reply With Quote
Old 06-30-2010, 07:06 PM   #15
jammin32j's Avatar
Try tapping the end of your wrench with a hammer, this works for me.
VP Pro, Agama
Hitec-7955's, 3Pk----AKA Racing Tires
Absolutehobbyz.com____Dirtrc.com
O'Donnell, D.I.R.T. R/C ultimate Tire Gluer
Jeremy Davis
jammin32j is offline   Reply With Quote
