Old 06-29-2010, 01:52 PM   #1
Questions?? glow plug
i was just wondering what would happen if i put a turbo glow plug in a motor that runs standard glow plugs.
Brinkster96 is offline   Reply With Quote
Old 06-29-2010, 02:01 PM   #2
FLASH1970's Avatar
Kind of new to RC Nitro but I know in turbo cars (like my Eclipse) you run colder plugs because the compressed air from the turbo is hotter than uncompressed air. So you need a colder plug that will resist heat better. If you run a colder plug in a car that's not turbo charged, it will not run as well because the temperature range where that plug operates the best, is not being reached. Hope that helps.
Flash
PHILIPPIANS 4:13
"I can do anything through He who gives me strength."
FLASH1970 is offline   Reply With Quote
Old 06-29-2010, 02:17 PM   #3
Flash
Huh? Turbo plugs will not work in a standard head. You would need to buy a turbo button head.
Shaun Davis
VP ProUSA
Mugen Seiki/Alpha Engines
Team Trinity
Miniracer23 is offline   Reply With Quote
Old 06-29-2010, 02:30 PM   #4
neobart's Avatar
The body of a turbo plug is wider than a std. plug, there's no way you can use one in the other. It may be called "turbo" but has nothing to do with real turbos.
Clockwork Racing Engines
neobart is offline   Reply With Quote
Old 06-29-2010, 02:32 PM   #5
808gx7r's Avatar
turbo nova plugs work in kyosho engines. i don't know how or why it would but, i had a old friend who tryed it, worked with huge power... for two minutes then stop'd and wouldnt start... it stuff'd the coil... the piston seemed fine, through in anther standerd an she fired up again
808gx7r is offline   Reply With Quote
Old 06-29-2010, 03:49 PM   #6
blktransam's Avatar
Trader Rating: 59 (100%+)
Flash
must be REALLY new ....a "turbo" r/c engine does not have a "turbo"..a turbo plug is bigger in diameter, and uses a tapper for sealing...as a std. plug uses a copper washer to seal the engine.
-Ryan Klemme
NemoRacingUSA.com,Beta tires,Agama, Triton Engines, Rocket Graphics, Byron Fuels, RcRenew, Major Art & Hobby, BuKu Products,
Midwest team manager for Nemoracingusa
Owner of Midwest Rc Tour
blktransam is offline   Reply With Quote
The best glow plug ignitor?? barrydidntknow Offroad Nitro Engine Forum 119 06-12-2016 11:23 AM
Glow plug chart - is there one? Mark_Australia Nitro Off-Road 10 11-23-2008 05:18 PM
glow plug hole stripped?? pinky2252s Nitro Off-Road 9 01-13-2008 07:57 PM
Shimming, nitro %, glow plug and timing blanks596 Onroad Nitro Engine Zone 30 06-15-2007 02:51 AM
Best glow plug ignitor?... Vyrus Onroad Nitro Engine Zone 9 03-02-2005 12:51 AM
