Old 06-29-2010, 10:51 AM   #1
Default Longer Runtime
Hi, I would to know what should I do more to get better fuel mileage with my .28 engine (exactly it's SH .28 P8 engine).
So far i have done:
- gas cooler
- O.S. 2060 pipe
- some sleeve and crankshaft mods (ports enlarged and glass polished)
I have reached 8 minutes race runtime on mid-open track. I've heard that adding a shim under the head can help - is it true? What else can I do to get my runtime longer?
wiktor0410 is offline   Reply With Quote
Old 06-29-2010, 11:03 AM   #2
Trader Rating: 12 (93%+)
So far i have done:
- gas cooler
- O.S. 2060 pipe
Easy on the throttle. Be smooth. Dont flip over and that will save you.
rcdude236 is offline   Reply With Quote
Old 06-29-2010, 11:10 AM   #3
After modding this engine i suddelny stopped blipping throttle in the corners and opening full throttle after landing or while entering the main straight Wheels were milling for 10-15 meters and then car was accelerating right
So since that time I use only smooth throttle and fuel mileage went better.
I think that 8 minutes during race is not so bad runtime. Now, I fill up every 7:30, and before after 6 minutes
Old 06-29-2010, 11:11 AM   #4
Davidka's Avatar
Trader Rating: 75 (100%+)
#1, replace the piston/sleeve and whatever else was modded. Unless that kind of work is done by someone that really knows what they are doing it will almost result in poorer run time.
#2, change to 20% fuel. tuning will be easier and run times will be longer. You may not even notice the difference in power.
#3 Consider a .21 engine when it's time to replace the .28. With a decent .21 and a decent tune you will have more power and WAY longer run times. 11+ minutes is not uncommon with truggy tanks.
Old 06-29-2010, 11:12 AM   #5
Cory Kerber's Avatar
It's a .28 so you can't expect great mileage. You can try a smaller carb venturi though.
Losi 8ight-Novarossi N21R-Hitec Servos-AKA-M11 Spektrum
*TEAM TERRIBLES*
Cory Kerber is offline   Reply With Quote
Old 06-29-2010, 11:19 AM   #6
ok, thanks for any replies
Old 06-29-2010, 11:29 AM   #7
RBMike's Avatar
6 or 7 mm venturi will help alot.
-EMBX6,T8 1400, RX8, 5S Lipo ,Elite-RC, RCM tray
-EMBX6,T8 1350, RX8, 5S Lipo ,Elite-RC, RCM tray
-B44 (Novak)
-ROAR 4 cell rule Blows
RBMike is offline   Reply With Quote
Old 06-29-2010, 11:54 AM   #8
I run a Ninja JX21-B01A .21 engine with a Ninja EFRA2042 pipe - I am getting 12 minutes of runtime, and it is only getting around 96 degrees celcius, so I can push more out of it.
I am thinking of changing from OS P3 plugs to OS P4 plugs to see if that will give me even longer runtime. And I've got more than enough power, so I am even considering a 6.5 venturi instead of the 7.
I gotta get this baby above the 15 minutes of runtime
Niklas Hansen
Team TCHobby / Team Upgrade-RC
Tamiya TRF417 / Speed Passion GT2.0 / Speed Passion V3 motors.
Nilks is offline   Reply With Quote
Old 06-29-2010, 12:04 PM   #9
VWVR6_T's Avatar
Send a message via MSN to VWVR6_T
Let us know when you hit the 15min. mark.
TLR 8ight 2.0 - Werks B5/2058 l Airtronics l Hitec l rev-rc.com l Werks Fuels l Sweep
TLR 8ight T 2.0 - Werks B5 Pro/2013 l Airtronics l Hitec l rev-rc.com l Werks Fuels l AKA
Ofna GTP l Hyper 8P Turbo
QUOTE by FLHX1550 "The Werks B5 is kind of a legend"
VWVR6_T is offline   Reply With Quote
Old 06-29-2010, 12:19 PM   #10
get 100 ft of fuel tubing and wrap your car with it.
"You are not understanding the fundamental principles of my fragmented personality"
Mugen
dreaux is offline   Reply With Quote
Old 06-29-2010, 12:33 PM   #11
I actually read about a guy in Australia who constantly got over 16 minutes of runtime on his Ninja, so it is doable
Niklas Hansen
Old 06-29-2010, 01:01 PM   #12
its a 28 your lucky to get 8 min. Get a .21
TLR - Spektrum - Horizon - TLR 8ight 4.0 - TLR 8ight-T 4.0 - TLR 22 4.0 - Orion
token is offline   Reply With Quote
Old 06-29-2010, 01:10 PM   #13
Suspended
Trader Rating: 202 (96%+)
i have also put a big fuel filter on mine and left the filter out of it, it holds alot of fuel!
inferno13 is offline   Reply With Quote
Old 06-29-2010, 02:50 PM   #14
Charles Godwin's Avatar
What you got to realise is, if the track is big (or fairly fast like over here in the EU). You won't have a hope in hell at getting 10mins. Drive smooth, regular clutch maintainence, no binding in transmission, .21 engine, tuned correctly and just drive the damn thing
DXR | CML Distribution | Paint by Turnip Paint | TKRgraphics.com
Charles Godwin is offline   Reply With Quote
Old 06-30-2010, 05:49 AM   #15
Chris K's Avatar
Trader Rating: 46 (100%+)
So far i have done:
- gas cooler
- O.S. 2060 pipe
One word: Sidewinder World Champion blend fuel!!!!!!!
Lots of folks have achieved significent run time improvement in addition to great engine life!
You might consider limiting throttle too - say 75% will make a BIG difference in run time without totally killing your power. My experiences with the smallest carb inserts is that they make the tune VERY hard to find; try staying with the 'medium' for your particluar engine, limit throttle and if you need fuel you should give the Sidewinder a whirl!
and noooooo, I don't work for Sidewinder; just a long time happy customer along with a lot of the drivers in the A Main at the off road fuel nationals last week.
Wherever you go; there you are!
Chris K is offline   Reply With Quote
Runtime on a 2C 5000mah lipo? PrimeAKF11 Rookie Zone 8 09-13-2009 08:42 AM
Best Fuel for Runtime???????? dsl Nitro Off-Road 13 10-27-2007 10:58 AM
Voltage vs Runtime ford_racing Electric On-Road 8 02-26-2005 07:04 AM
