Old 06-29-2010, 12:53 PM   #16
jeff_ellis_9's Avatar
I have a tube of Trinity BUSHING oil I used to use for my electric motor bushings, would this also work for bearings or does it have to be something special?
Team Losi Buggy
GO Tech 5 port RB Mods
AKA
HiTec
Spektrum DX3S
jeff_ellis_9 is offline   Reply With Quote
Old 06-29-2010, 05:37 PM   #17
also, to add to this, I have a question:
What bearings do you guys oil the most often? I was cleaning up my buggy today from my last race and so far (and was the easiest) I have done all the wheel/axle bearings being two on each side of the carrier. And tomorrow I will oil the bearings that is on the gearbox where the center drive shafts go into. Those shouldnt be that hard.
But reason I ask is well some of the bearings are a pain to get to, or at least you have to take a bunch of crap off to get to it. (such as center diff bearings and front and rear diff bearings and also the motor bearing/clutch bell bearings). I understand going through the trouble for REPLACING the bearings, but im just talking about oiling them after a race day. And also how often DO you guys re-oil your bearings???
Team Losi Buggy
AKA
HiTec
Spektrum DX3S
Old 06-29-2010, 05:44 PM   #18
helivaguy's Avatar
Trader Rating: 42 (100%+)
tri-flow oil.
how often depends on rubber or metal shielded.
helivaguy is offline   Reply With Quote
Old 06-29-2010, 06:55 PM   #19
808gx7r's Avatar
some of the tamiya stuff is really good!
808gx7r is offline   Reply With Quote
Old 06-29-2010, 07:10 PM   #20
JAMMINKRAZY's Avatar
Trader Rating: 17 (100%+)
Originally Posted by Reno View Post
I am rebuilding my bearings on my MBX6T and wanted to know what type of lubricant most of you use. They are standard bearings. Any ideas and input would be appreciated.
Thanks...
Trash can works best for me. At a dollar a pop, they're hardly worth the effort/risk of cleaning and re-using them. Just my opinion.
-Koby Kubrin-
Thanks to my Sponsors:
Serpent America | Team Novarossi | Desoto Racing | Race AKA | Ridgeway Bodies
JAMMINKRAZY is offline   Reply With Quote
Old 06-29-2010, 08:17 PM   #21
i've used synthetic engine oil, ATF oil, some branded bearing oil and ca't tell the difference
cheapskate.brok is offline   Reply With Quote
Old 06-29-2010, 08:45 PM   #22
isn't oil a bit too light for high speed bearings? i personally use synthetic bearing grease...
Powered by: MASTERCARD and VISA
If you're in control, you're not driving it fast enough!
XRAY / NOVAROSSI / SANWA / AKA TIRES / BYRON FUEL
ganymede is offline   Reply With Quote
Old 06-29-2010, 10:42 PM   #23
mblgjr's Avatar
Trader Rating: 86 (100%+)
I've used Mobil 1 5-30 and other "light" oils in bearings. It stays a long time as long as you don't over-do it.
Grease has a fair amount of drag, though it will stay in the bearing longer and generally is a better lubricant. But again, drag is an issue.
Now I typically wash the bearings out and get them clean, then lube them with the Dupont Dry-film and let it dry, then place a tiny amount of oil and put the seal back in.
I will only clean bearings once, then they go in the trash. Inner hub bearings get replaced the most and at $1 or less a piece I don't take the time to clean them either.
Team Associated Reedy JConcepts.net FusionX USA
mblgjr is offline   Reply With Quote
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
How to clean and what lubricant to use on RC bearings cliffhanger Electric Off-Road 36 12-26-2016 09:21 AM
Best Lubricant for Bearings? WD40 Electric On-Road 103 02-17-2013 06:36 AM
Mystery of the Dissapearing O-rings! joe of loath Nitro Off-Road 10 10-28-2007 10:02 AM
